Old 23-05-2008, 10:29 AM   #1 (permalink)
gopz's Avatar
Default Pen drive issue
I got a 2GB pen drive as a gift from ICICI bank. Unbranded.
When I insert it into any of the USB ports, it shows "Removable Device" but I am unable to copy any data into it or even format it. It just locks up when I try to access the drive.
Is it damaged? my OS is Vista
gopz is offline
Old 23-05-2008, 12:08 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Pen drive issue
wht msg do you get????
anyway, confirm that it isn't writeprotected. just see tiny switch somewhere else in your paindrive.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 23-05-2008, 01:18 PM   #3 (permalink)
unbranded...at least they could have given a proper gift...lack of genuiness
realdan is offline
Old 23-05-2008, 01:37 PM   #4 (permalink)
gopz's Avatar
There was no switch..but lemme check again...
but... even if it is write protected, it should not hang or lock up, correct?
I cant even right click and choose properties. It just freezes
gopz is offline
Old 23-05-2008, 05:41 PM   #5 (permalink)
may be its not installed properly ,go to device manager and check wether the device is well detected and well functioning(find it by clickin in generic volume) and check wether it supports windows vista or not.try checking it on others computer having xp.and did u write somthin before if so, then any how try formatin it and check for virus if possible....
JYO_JVL is offline
Old 24-05-2008, 09:49 AM   #6 (permalink)
Hmm,
A pen drive which behaves like a corrupt memory card, isnt it? Well, Vista isnt supposed to do that,, I guess you better listen to what he says!
Pirates-of-India is offline
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
Flash Drive Unmount Issue lalam Hardware Q&A 1 29-08-2007 01:29 PM
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
DVD Drive Issue thewisecrab Hardware Q&A 2 23-02-2007 06:27 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
