Old 23-05-2008, 07:05 AM   #1 (permalink)
Ranjya's Avatar
Default Chassis gives shock:-(
I assembled my first PC.
I was expecting studs or spacers along with cabby.
iball does not give..........only with grabit I hear.
iball mobo panel also cannot be removed.
Mounting holes have elevation.
This is suposed to solve the issue of spacers/studs.
But my chassis and all mounting screws give a shock.
I even tested with a tester.
The powder coated part of cabby does not give shock.
Any suggestions?
Don't buy iball cabby...flimsy construction......my
old mercury cabby was superb in comparision.
Ranjya is offline
Old 23-05-2008, 07:11 AM   #2 (permalink)
NP : Crysis
xbonez's Avatar
Default Re: Chassis gives shock:-(
i've been using an iball grabit for over an year now, and am extremely happy with it...very sturdy and spacious. but i guess the other cabbys by iball aren't so gud
xbonez is offline
Old 23-05-2008, 07:14 AM   #3 (permalink)
prasad_den's Avatar
Is the earthing proper..? Probably that is where the fault lies..
prasad_den is offline
Old 23-05-2008, 09:52 AM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
^^yep. The problem is with the earthing. If the earthing is not proper, even Cooler Master cabinet will give shock.
Check the socket, powercable etc.
desiibond is offline
Old 23-05-2008, 01:06 PM   #5 (permalink)
simply use a spike guard with earthing leak detector/display between the power supply and ur pc . u chk the leds display u will come to know abt the earthing fault.
vardesh is offline
Old 23-05-2008, 01:17 PM   #6 (permalink)
i agree..it is an earthing problem or an issue with your electrical wiring in your house..get a qualified electrician to check the wiring
you need to connect to a mains with three connectors..earth, neutral, live...
make sure apart from the live..none of the others are leaking electricity
Stop running your computer for now until the problem has been rectified...
realdan is offline
Old 23-05-2008, 07:25 PM   #7 (permalink)
Tech Addict
Check your earthing ASAP.
arupch is offline
Old 23-05-2008, 08:43 PM   #8 (permalink)
shashank_re's Avatar
Even i have kinda similar problem with CM690. The power cable that came with CM600W PSU has a 2Pin(no earth pin) plug rather than 3Pin that usually comes with other PSU.Do i need to change the power cable?Though now iam not getting any shock.
shashank_re is online now
Old 23-05-2008, 09:23 PM   #9 (permalink)
i think it is better that you change the power cable to a 3-pin one...
realdan is offline
Old 24-05-2008, 10:43 PM   #10 (permalink)
channabasanna's Avatar
Check for earthing, even if earthing is good, check your spike buster is it giving reverse current, my older system i suffered the same once. I had switched off the UPS and just touched the Cabinet i got a shock. It was coming from the monitor, later i changed my spike.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 26-05-2008, 07:23 PM   #11 (permalink)
Ranjya's Avatar
My spike has 2 red lights on.
It says L & N reversed.
Can this damage my system?
How to do that.
I will get a electrician tommorrow.
Will a UPS solve the problem?
Ranjya is offline
Old 26-05-2008, 07:32 PM   #12 (permalink)
The Sorcerer's Avatar
Power supply has its own earthing cable. Maybe that has gone bad.
Hardware BBQ
The Sorcerer is offline
Old 26-05-2008, 09:11 PM   #13 (permalink)
Ranjya's Avatar
This is a new Cooler Master 500W PSU.
Ranjya is offline
Old 26-05-2008, 10:21 PM   #14 (permalink)
Get your wiring fixed at the earliest, I don't think a UPS can solve this problem, its always better to fix this sort of electrical issues,
Your PC peripherals can get damaged.
Xccentricity is offline
Old 27-05-2008, 02:30 AM   #15 (permalink)
bow chicka bow wow
neeru_igi's Avatar
i've had similar problems too.check the earthing.get it fixed soon or it'll damage your HDD.
Ugraded rig....
C2D e7200, Gigabyte G31s2l , 2Gb transcend (800mhz) ,seagate 250 gb ,nV 8600gt
neeru_igi is offline
Old 27-05-2008, 11:32 AM   #16 (permalink)
ajayritik's Avatar
When I first purchased a PC way back in 2001 even I faced similar issues. It was only after I had the earthing fixed by an electrician did the problem resolved. So you have to wait till you have an electrician check your wiring.
ajayritik is online now
Chassis Intrusion, Fan, SMPS Fan configuration, AMD Away Mode narangz PC Components / Configurations 9 15-03-2008 04:13 PM
Urgent Hardware & Chassis saurabh DH Hardware Q&A 7 10-03-2007 11:57 PM
Help in buying chassis. john_the_ultimate Hardware Q&A 14 19-08-2006 02:50 AM
Atlast a world class Chassis in India gxsaurav QnA (read only) 24 26-08-2005 01:38 PM
