Old 22-05-2008, 09:33 AM   #1 (permalink)
Love Tech More than food
rahul_u_know_me's Avatar
Default why the computer restarts
i am having and Amd config 512 ram and iball cabinate , my computer restarts every now and then, i dont know why? what may be the problem?
i surface scanned the harddisk it found bad cluster(single) and corrected it. but than also it restarts. and the harddisk is working fine in other systems.? what may be the cause?
Cant Live without My Computer even for a day!!
rahul_u_know_me is offline
Old 22-05-2008, 11:54 AM   #2 (permalink)
k_blues24's Avatar
Default Re: why the computer restarts
Check ram modul, rub golden edges with eraser. In most cases psu is not delivering the optimum voltage it shud b atleast 400 - 450 W also check 4 graphics Other problem is may b ur OS gets corrept re-install it (repair it)
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 26-05-2008, 06:56 PM   #3 (permalink)
hay i did wat u said an my prob solved via ram.... i removed it cleaned it and changed the slot.... thanks man
Computer restarts ComputerUser Software Q&A 2 10-01-2008 03:17 PM
Computer Restarts on downloading from net bkmishra1000 Software Q&A 1 27-03-2007 04:01 PM
computer restarts raul_8 Software Q&A 1 26-01-2006 08:02 PM
Computer restarts when connected to DVD RW ram2005 Hardware Q&A 7 11-01-2006 10:34 AM
COMPUTER RESTARTS SHell QnA (read only) 4 19-10-2004 01:41 AM
