Old 22-05-2008, 02:10 AM   #1 (permalink)
Fahd.Malik's Avatar
Default I am planning to buy this, is it ok?
Hi Guys
I need your suggestions before going to buy the config i have finalised. I am going to buy it tomorrow/day after tomorrow.
I will be using it for : Photoshop CS2(most of the time), Studio 8, Visual studio 2005, Torrents, MS office, Games(no hardcore gaming) , surfing And everyday stuff. This config will be used 24X7(most of the time!)
I will be purchasing it from Nehru Place , Delhi
Proccy: E7200 2.53ghz(is 3 MB cache good enough?) price?
Mobo : Abit IP35E ( as u guys say its good) price?
Ram: 2X1GB 800mhz Transcend( is there a 2GB stick, is it better?) price?
HDD: 250GB (seagate? WD?) price?
GPU
: 8600GT 256MB ddr3( Asus? gigabyte? Msi? confused) price?
Cabinet: CM E330( i think its good) price?
Power supply: i am not sure if a 400W will do? or will i need 450W?
powersafe or corsair?
Dvdwr: samsung is fine?
UPS : cheapest and good.. just need to protect hardware incase of power faliure. will buy it later
did i missed anything?
Please add your views on this config, and let me know where i can save money. My budget is tight, 25k-26kMax
i will go for shopping only after reading comments from you guys and if its not raining
Thank you
Fahd.Malik is offline
Old 22-05-2008, 02:52 AM   #2 (permalink)
NP : Crysis
xbonez's Avatar
Default Re: I am planning to buy this, is it ok?
my suggestions -
avoid samsung DVD-RW...go for Lite-On, Sony or LG
might as well throw in a little more and go for a 320GB HDD
GPU - as u won't be indulging in hardcore gaming, i s'pose u don't plan to overclock ur gfx card. in that case, go for 8600GT from MSI..it is fanless and hence totally silent
xbonez is offline
Old 22-05-2008, 03:46 AM   #3 (permalink)
Fahd.Malik's Avatar
Hi thanks for your comments.
Yep i wont be Ocing GPU, but still, a fan is better than no fan? as i heard 8600GT goes hot most of the time.. whats the price i can get 8600GT for?
Also i am unsure about , Is E7200 compatible with IP35E?
I will be overclocking my Cpu to 2.8-3ghz from stock 2.53ghz.
And i like the reviews of IP35E, any other good option for mobo with same price range and overclocking capability?
PSU? 400W? 450W? 500W? plz comment on this, i am totally unsure about which one will suit me the best.. i dont want larger psu if its not going to be used to its worth...
Also is there a considerable performance difference between a 3mb and 6mb cache? is E7200 good enough for my usage?
thank you.
Old 22-05-2008, 03:53 AM   #4 (permalink)
NP : Crysis
xbonez's Avatar
the MSI 8600GT retails for about 5k i think. it comes without a fan but has copper heatpipes that keep it adequately cool at stock temp. a friend of mine, maverick340 has the same gfx card and has NEVER experienced overheating issues. he runs it at stock speeds and plays all the latest games such as Crysis, COD4, COnflict Denied etc.
xbonez is offline
Old 22-05-2008, 10:55 AM   #5 (permalink)
Fahd.Malik's Avatar
Thanks Xbonez..
Well i still have doubts guys...
1) E7200 works with Abit IP35E?????
2) power suppy unit?? coolermaster Extreme 460? Corsair vx450? or will a 400W from powersafe do the job?
3) E7200 , 3mb cache good enough?
4) Can you guys suggest the price for the items i listed in my earlier post?
Thank you
Old 22-05-2008, 11:09 AM   #6 (permalink)
You gave been GXified
gxsaurav's Avatar
For photoshop, the more cache the better
U wanna overclock?
Don't buy 1 2GB Stick, buy 2x1gb
Get western digital WD3200AAKS, 320 GB, 16 MB buffer for Rs 3,200.
GPU: 8600GT 256MB ddr3( Asus? gigabyte? Msi? confused) price?
Get Radeon HD 3650 or 3850. More features then 8600GT
450 W Cooler master should be enough.
about.me/gxsaurav
gxsaurav is offline
Old 22-05-2008, 11:32 AM   #7 (permalink)
Fahd.Malik's Avatar
Hi gx_saurav
Yep, i want to overclock a little, not much. Will take my 2.53GHz Stock to maximum of 3Ghz. That too if i need to.
Is Abit IP35E good for that? any other option of same price range i can consider??
Will Abit IP35E work with E7200? 45nm
Let me know which motherboard u have on your mind?
What are their Cost?
Thank you
Well, one more thing i want to ask is E7200 available in Nehru Place Delhi????
plz reply on this guys..
============EDIT================================== ===
Finally i bought my Rig today from SMC international, nehru place
Proccy: E7200, 5700/-
Mobo : Abit IP35P , they did not had IP35E. 5200/-
Ram: 1GB 800 MHz 1050/-
HDD: WD 250GB. 2350/-
GPU: xfx 8600GT ddr3 256mb. 4700/- did not had Msi, CE did not had it either..
Cabinet: CM 330 Elite. 1550/-
PSU: CM 390 Extreme(budget constraint, and SMC ensured me that it will work good for me. 1600/-
DVDWR: Sony 1150/-
Speakers: creative inspire 2.1 . 1500/-
Total cost i paid after VAT : 25600/-
Well i felt that i could have bargained more, but i was fine till these items didn't crossed my budget..and more over i wanted to buy all my items from same shop.
I hope its good config
comments?
gx_saurav? xbonez?
thank you for your suggestions...
Planning to buy a Camera & AC paragkalra Chit-Chat 8 07-04-2008 10:06 AM
Planning a New machine (just cpu + MB) - AMD? alsiladka Hardware Q&A 2 02-01-2008 11:34 AM
planning 2 go for new laptop... help pls taken Laptops and Netbooks 2 24-01-2007 09:09 PM
Planning On Buying A New Phone...Help MDK Buying Advice 38 21-01-2007 04:26 PM
does anyone own a mac mini(i'm planning) gauravsuneja Networking 11 23-10-2005 01:35 PM
