Old 21-05-2008, 12:05 PM   #1 (permalink)
Arrow Processor prference
Can you guide me to select Q6600 and E8300,I am in the process of buying a desktop.
premkdee is offline
Old 21-05-2008, 12:30 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Processor prference
1st tell us ur budget and wat u plan to use ur pc for?also do u upgrade frequently?
hellgate is offline
Old 21-05-2008, 12:44 PM   #3 (permalink)
Well I got me an e8400 and I'm really liking it. I would imagine similar performance from an e8300. If you check benchmarks, the Q6600 doesn't perform as well in most cases, but there's lots of talk about the quad cores becoming much better once they're utilized properly. I personally would get e8300 as it reports better performance, and by the time quad cores become the norm and duals are obsolete, it might be safe to assume the Q6600 may too be a bit old.
馬鹿は死ななきゃ直らない
nikkuchan is offline
Old 21-05-2008, 07:42 PM   #4 (permalink)
Skulltrail's Avatar
performance - e8300/8400
futureproof - Q6600
1 4M TH3 SKULLTR41L D54OOXS QX9775
Skulltrail is offline
Processor Name??????Big Question.1 Processor 3 Names vutonium Hardware Q&A 12 05-07-2007 11:07 PM
which processor to buy??? thinktwice Hardware Q&A 2 18-03-2006 05:35 PM
Do i need a new processor???? moshel Hardware Q&A 10 04-02-2006 10:46 PM
BEST AMD PROCESSOR mandar5 CPU / Motherboards 1 25-09-2005 05:21 PM
Best processor navino87 CPU / Motherboards 6 13-05-2005 02:04 PM
- by c4u
