Old 20-05-2008, 04:06 PM   #1 (permalink)
Ranjya's Avatar
Angry Abit IP35-E
Hello all,
I have following config I have assembled :
E2180
1x2GB 800 RAM Transcend
160GB IDE HDD
DVD ROM IDE
8500GT
Abit IP35-E mobo
Machine boots....BIOS
Date entered.
On boot starts to beep repeatedly.
I had to attach HDD as slave and DVD rom as master
due to IDE cable problem.
Will I require a SATA DVD to install OS?
or atleast to boot windows.
Boot options does not have any IDE only sata, USB, HDD etc
Help!!
Also my processor temp is 82 C that is high me guess.
my heat sink one of the clips wouldn't go in fully.
Almost sprained my thumb.
reply soon.
Ranjya is offline
Old 20-05-2008, 04:21 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Abit IP35-E
do not run ur PC until that heatsink is properly fixed or u will burn ur processor
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 20-05-2008, 04:34 PM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
+1
if your thumb is sprained, get someone else to do the job for you.
your processor is a precius commodity.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 20-05-2008, 04:56 PM   #4 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Originally Posted by Ranjya View Post
Hello all,
E2180
160GB IDE HDD
DVD ROM IDE
8500GT
Abit IP35-E mobo
Date entered.
Help!!
reply soon.
If you don't know how to install processor, DON'T INSTALL IT YOURSELF. Take it to the dealer and get it installed by them. You will either damage the processor or damage the heatsink.
desiibond is offline
Overclocking e8400 with abit ip35-e ratedrsuperstar Overclocking 3 05-05-2008 12:17 AM
Overclocking abit ip35 ionicsachin Overclocking 17 10-04-2008 12:29 AM
abit ip35-e or msi neo2-fr ionicsachin Hardware Q&A 14 28-03-2008 12:06 AM
ABit IP35-E parimal Hardware Q&A 2 21-02-2008 10:13 AM
Quick Look at ABiT IP35-Pro Choto Cheeta Reviews 12 11-02-2008 01:17 AM
- by c4u
