Hi, Guys !
Can u Understand my Hinglish writing. Try it Plz.
well, mere pas ek sys. aya 865 me P4-2.66 775 socket ke sath.
jisme display problem tha. socket ko dekhne se uski 2 pin damage
mili. mobo ko faulty jan kar cpu ko jab maine ek other running 865
me chek kiya tab usme bhi display nahi aaya aur nahi PC boot huaa.
Its all ok now here. CPU May be faulty.
But asli problem to ab start hua. jab maine running PC me uske own
cpu install karke On kiya tab process
F8 menu (sefe mode menu) me stop
ho gya. wha par maine
last known good configration option par Enter kiya
tab Booting process OS ke
Welcome screen par mostly
10 sec ke bad
shut-
down ho gaya. then maine 2-4 bar aur try kiya ki safe mode me desktop
tak jaa sku. but ho nahi paya, system bar-bar shut down ho raha hai.
(PC-1)
this one is starting one, and second one-me risk lekar maine Faulty
CPU ko apni MOBO me test kiya but result -yha bhi same 1st sys ki tarh hai.
is sys ke HDD jo ki IDE se connect tha ko format kar diya.(kisi dusre PC ke
support se) ab
XP ka setup chala raha hoon tab bhi
setup window tak jakar
vaise hi 15-20 sec bad
shut down ho jata hai.
(PC-2)
here is my problem- 1. what happen with our PC's(1-2) ? Why it's not booting.
2. Is it fault has came into our boards ? In my understanding it is'nt posible
because hardware maintainance sector me substitution method ka hi mostly
hum sab log ise karte hai.
but suggestions from u people is mostly welcome.
if their is any fault in the our mobo then what Should be I Does ?
U people also USE my Email, and well understanding my situation.
Bake-ji
