18-05-2008, 06:36 PM
my screen is floating
Hello anybody can help me out i have AMD sempron 2500+(1.41 Ghz) 256Ram and 40 gb HDD windows xp professional installed my problem is that my system screen is floating when i drag down i have tryed incrase the ram for 512 but still am facing the same problem,i have changed the monitor also but still same problem plz help me out thanku.
Hidayath
18-05-2008, 07:36 PM
Re: my screen is floating
Confused. . . . plz post ur exact problem.
19-05-2008, 01:51 PM
when i drag or scroll down any pages my screen is floating so wht to do
19-05-2008, 02:18 PM
still confused, what exactly is floating ? like watery stuffs or what ?
19-05-2008, 03:20 PM
स्क्रीन तैर रहा है क्या?
teyrney k liya to paani chaahiya, usme bhi swimming bahut zaruri..........
still confused, wht does screen floating means?????????
20-05-2008, 12:58 AM
i think u havent installed the VGA drivers ..commonly known as display drivers, grafix drivers or drivers for the display adapter .......... pop in the Motherboard drivers CD in the optical drive and then install the drivers ..... see if u r nt getting the STANDBY option in system "turn off" menu too....
20-05-2008, 01:18 AM
left this forum longback
weak crt,look for some electro-magnetic interferences
20-05-2008, 01:36 AM
Coming back to life ..
^^ Yupp .. Dont keep your cell phone near the monitor (if its a CRT). Also check if power fluctuation is there .. I remember when I had a CRT monitor the display used to fizzle if it was running on inverter ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
20-05-2008, 04:36 AM
Evolving Rapidly...
^^also speakers.......
aap ne mujhe bulaya ji?
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
Reason: Automerged Doublepost
20-05-2008, 08:25 AM
Abey LCD to nahi hai? Liquid Crystal Display!
20-05-2008, 08:39 AM
Point Blanc
bhai log harry potter jab bachaane ke liye khud aa gaye hoon to baki kya jaroorat. Harry says it all, besides keeping your electomagnetic instruments away.
you should have told initally what type of monitor do you got.
Besides updating the drivers if this happens randomly then switch off and on the display. Also in CRT there is an option to Buzz the monitor, someone correct me with the exact term, I do not have a CRT to check and tell it right away.
20-05-2008, 08:59 AM
^it is called "degaussing"
20-05-2008, 11:50 AM
Legen-wait for it-dary!
the liquid crystals in his lcd have melted due to the hot sun and are sliding down the monitor due to gravity, and the image is floating on top of it...
no?
21-05-2008, 12:15 AM
the guy-OP havent replied yet ....... shayad display liquid ban ke beh gaya ......
21-05-2008, 12:19 AM
even I have seen old CRT's which beep fulltime to make your ear broken
LCD Zindabad!Hope LCDs should come under Rs6000 this year end
this bulky CRT's are taking lot of real estate
21-05-2008, 12:38 AM
Evolving Rapidly...
^^the humble crt may occupy a lot of space and produce enough heat, to be used as a heater but it has nonetheless has worked like a charm for the last few decades.... so give it some respect
