Old 17-05-2008, 11:12 PM   #1 (permalink)
Exclamation keyboard acting funny
I have a silicon usb keyboard which suddenly stopped responding with certain left section keys (6-8 keys), I changed the USB port assuming the port is acting funny but that did not help either.
Assuming the keyboard gone bad, I replaced it with multimedia keyboard PS2.............all worked fine for 3-4 days then the new keyboard numeric keys stopped working, I was locked out of my computer since my password include @ which I could not type.
After 2 -3 tries into safe mode it started working again normally leaving me confused as to is this a software problem or hardware problem.
Tried with XP/vista both so its more confusing, have u ever had such problem.
ranjan2001 is offline
Old 18-05-2008, 09:59 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: keyboard acting funny
I don't think dis is software issue instead its hardware issue.
By the way KB u r using may have unclear circuits printed in plastic flim or num lock is of or KB isn't connected properly.
Also check sticky are disabled.
Anyway, u may use symbol keys as these key has numeric keys also.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 18-05-2008, 10:56 AM   #3 (permalink)
I should have been more clear.
The number keys are working but the symbol keys were not working in the new keyboard, now the new keyboard is working perfectly, I don't know why it was acting funny earlier.
The old keyboard has following keys not working
Tab key
Esc key
A
S
Z
X
Q
so its left side keys gone bad.
I have never seen a keyboard gone bad so I don't know they die in such a way.
Where do you check sticky? I don't see any such thing in Control panel>keyboard properties.
Old 18-05-2008, 12:41 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
control panel->accessibility options
dheeraj_kumar is offline
Old 18-05-2008, 12:52 PM   #5 (permalink)
Checked it there its not selected, so it seems something within the mobo hardware is acting funny.
Old 18-05-2008, 01:53 PM   #6 (permalink)
dhanusaud's Avatar
hehe...u r using cheaper keyboard around rs. 150 to rs. 200, which performance is very very weak. sometime i too get same compliant from some guys same as yours.
these kind of keyboards have very weak circuits printed in plastic film, & so it sends weak signals to processor. sometime it works fantastic.....but sometime it works nasty. when keyboard gets problem, i try a lot but i fail to solve but restarting comp sometime it works.
i recommend to change your keyboard from better manufacturer like logitech, intex & blablabla...........don't choose cheaper one.
Old 18-05-2008, 02:03 PM   #7 (permalink)
Well the 1st silicon keyboard which developed problem with partial keys was bought for 450/- last Jan 2007, don't know if its cheap.
The present one is logitech multimedia keyboard borrowed from a friend who is not using the comp.
Old 18-05-2008, 02:11 PM   #8 (permalink)
dhanusaud's Avatar
not a bad keyboards as well, but pal I repeat circuits of KB is going worst or connectuion between ur system & keyboard is not clear.
Old 21-05-2008, 02:07 PM   #9 (permalink)
Dreaming Future
kin.vachhani's Avatar
try plugin your KB on another system and test for some day...or get it replaced i dont think so it would neither connection problem nor software problem. Could be your KB problem.
World without Computer is like a man without Brain.....
kin.vachhani is offline
Monitor is acting weird...plz help.. abhi_10_20 Hardware Q&A 3 22-11-2007 12:09 AM
Gmail filter is acting up! phreak0ut Internet & WWW 6 06-11-2007 07:14 PM
firefox 2 acting funny on clicking links ranjan2001 Software Q&A 1 04-12-2006 07:09 PM
Google is acting up max_demon Software Q&A 13 16-11-2006 07:05 AM
my computer acting strange adit_sen QnA (read only) 3 28-09-2004 05:03 PM
- by c4u
