Old 17-05-2008, 11:00 PM   #1 (permalink)
dhanusaud's Avatar
Question IDE problem
Guys,
I m lil bit confused. . . . will hdd & dvd rom work in single IDE cable?
My frnd has only one ide port in his motheboard.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 17-05-2008, 11:05 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: IDE problem
Of course, I am using it in my desktop. But its HDD and DVD writer!
kumarmohit is offline
Old 18-05-2008, 04:56 AM   #3 (permalink)
Point Blanc
an IDE cable which got 2 ports, easy to find, sure one IDE cable for both will work
acewin is offline
Old 18-05-2008, 06:26 AM   #4 (permalink)
Seed is the Life!!
shift's Avatar
yes it will work...... set the HDD to Primary Master and DVD ROM to Primary Slave or u can set the HDD to Primary Slave and Primary DVD ROM to Master........its your choice
Stupidity Causes Cancer !!
shift is offline
Old 18-05-2008, 08:31 AM   #5 (permalink)
dhanusaud's Avatar
thanks guys,
confusion cleared.
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
- by c4u
