Old 17-05-2008, 04:53 PM   #1 (permalink)
Post cant view hidden folder
Hello i cant view the hidden folder if i click on show hidden files also it again disable and i cant view so plz help me out if is it possible plz mail me s_hidayath_khan@yahoo.co.in
Hidayath
hidayath7 is offline
Old 17-05-2008, 09:26 PM   #2 (permalink)
gurujee's Avatar
Default Re: cant view hidden folder
virus, trojan, spyware
gurujee is offline
Old 18-05-2008, 12:39 AM   #3 (permalink)
Jack Sparrow
joey_182's Avatar
buddy u must do search on this forum before posting for such common problems..
anyways..
do scan with ur anti virus and then follow our genius mind..
here's ur solution
http://thinkdigit.com/forum/showthread.php?t=61413
KHAO PIYO TE AISH KRO!!
http://twitter.com/puneetshrma
joey_182 is offline
Old 18-05-2008, 01:10 AM   #4 (permalink)
Tech.Masti's Avatar
Old virus, update antivirus and scan
Tech.Masti is offline
Old 18-05-2008, 06:27 PM   #5 (permalink)
thanku
Old 21-05-2008, 02:01 PM   #6 (permalink)
Dreaming Future
kin.vachhani's Avatar
it is sort of after effect...it cant be solved by anti virus. Even if u will remove the virus u still wont be able to c the hidden folders..
open regedit and go to .>HKEY_CURRENT_USER\Software\Microsoft\Windows\Cur rentVersion\Explorer\Advanced
in advance
change
"hidden" value to 0
"ShowSuperHidden" to 1
"SuperHidden" to 1
Will do your work
World without Computer is like a man without Brain.....
kin.vachhani is offline
View/Add hidden files/folders in Nero g_goyal2000 Software Q&A 4 25-05-2008 08:27 PM
View hidden files error !! passion_unlimitedd QnA (read only) 1 25-10-2007 02:00 PM
Cannot view hidden files sridatta Software Q&A 6 23-10-2007 08:57 PM
Help Cant View Hidden Files amancoolguy777 QnA (read only) 6 01-10-2007 02:59 PM
Unable to view hidden files captainshailendra Software Q&A 1 18-06-2007 03:43 PM
- by c4u
