Old 17-05-2008, 01:48 PM   #1 (permalink)
Lost in LOST
sagardani's Avatar
Default How to play .mkv files on television (or HDTV) w/o converting them to DivX ?
I've loads of compressed HD stuff on PC and my hard disc is getting full of it. So I need to burn them on DVD. But I just want to know- how can I play them on TV? I don't want to waste time in converting them in DivX. I think Xbox plays mkv files. So if just burn right now them on a DVD as data disc and insert it into any varient of latest Xbox 360 will it play ? One more query- PS3 plays mkv ?
Reply...
Cybernetic, biological A.I, genetically engineered specially to survive in Earth's atmosphere.
sagardani is offline
Old 19-05-2008, 09:39 AM   #2 (permalink)
Lost in LOST
sagardani's Avatar
Default Re: How to play .mkv files on television (or HDTV) w/o converting them to DivX ?
Reply someone yaar.... Xbox owners know about this????
Old 19-05-2008, 08:34 PM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
mkv is Matroska File Format that is a variant of compressing x.264 Videos.It just acts as a container.FYI PS3 plays x.264 encoded videos
techtronic is offline
Old 19-05-2008, 09:36 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
I do not own a PS3 nor an xbox so practically I have not experimented on these, AFA I know to play a file a player must support the codec AND the container as well. Like my Philips DVD player supports divx n xvid but with only AVI as the container, if I change it to say MP4 it wont play. I am sure similar is the case with PS3 and xbox. PS3/xbox AFA I know only supports MP4/AVI container for x264/Divx files. But again there must be workarounds deviced by hackers and consol gods . Uncle google might help. the following link also might help in clearing your doubts....
http://forum.videohelp.com/topic325958.html
As for now I guess the only best way is to either convert the video to MP4/AVI container or connect your computer with your TV (direct DVI to HDMI if your TV has HDMI input) or through S-Video........ again if your TV has S-Video....)
sam9s is offline
Old 19-05-2008, 10:03 PM   #5 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
mkv is NOT a container for x.264 videos. its a container for nearly every single audio codec and video codec and subtitle format.
First see its inside and find out what it has.
And Xbox has XBMC, Xbox Media Centre. It plays each and every format. You need to download the software, place it in a DVD and place the files you have in a certain place in the DVD. Then insert the DVD into your Xbox/360 and it will run the "game" which is infact a media centre software. It plays the songs for you.
And remember, it has features equal to Kaffine media player, meaning it supports nearly every single thing under the sun. Much more than VLC.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Need help regarding converting my divx(avi) videos into 3gp sakthirajesh Mobiles and Tablets 1 26-04-2008 12:21 PM
Which format to choose while converting video files so that they can play on my vcd ? aQi_g Software Q&A 5 13-11-2007 07:23 PM
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
reg the converting RM video to divx format. sudheer17682 Software Q&A 6 28-03-2007 04:36 PM
How to play divx video files on dvd players coolrupesh Hardware Q&A 4 05-12-2005 01:57 PM
- by c4u
