Old 16-05-2008, 05:54 PM   #1 (permalink)
Question Query :Reving up my PC ?
i hav n old Intel 3 with 128k Ram n one Samsung 4GB n one Seagate 40GB hard drive.
im running Windows XP proffesional n wud b willing to switch over to Linux if a solution is possible.I use the PC mainly for media purpose : music,video,downloading ....no gamin.
i wanted to noe :
if there is any way to use the Samsung hardrive to boost my speed (ram)?
digitalKing is offline
Old 16-05-2008, 08:37 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Query :Reving up my PC ?
Your rig probably should be pentium 3 with 128MB Ram
Yes, you can run & install linux - but I doubt if linux will run well for multimedia with only 128 MB Sd or ddr ram.
I'll suggest you to invest you in a complete new rig & use your old rig as download box.
No there is no way you can use your HDD to boost your system speed in place of Ram.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
c2d query ramana321388 QnA (read only) 8 09-10-2006 08:25 PM
asp.net query daivagna QnA (read only) 2 05-09-2006 03:12 PM
gta sa query nishant_garg89 Gamerz 5 05-02-2006 09:29 PM
IE query godsownman QnA (read only) 9 05-09-2005 03:24 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
- by c4u
