16-05-2008, 12:56 AM
Evolving Rapidly...
Which to choose b/n SATA or IDE optical drive?
well prices in mumbai for IDE drives are
1100 - liteon
1200 - samsung
1300 - sony.
i decided to go for sony.
i wanted a SATA optical drive, but a shopkeeper said "IDE better than SATA"? also he sold SATA drives boxless for 1450, saying its made by sony.
So which one is better?
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
16-05-2008, 01:07 AM
Google Bot
Re: Which to choose b/n SATA or IDE optical drive?
There is a Samsung SATA available for 1.15k. Get it. Dont remember the no.
16-05-2008, 01:48 AM
Evolving Rapidly...
ok. but which is better SATA or IDE?
16-05-2008, 02:10 AM
Google Bot
In disk drives, Doesnt matter much. Cos the max data transfer speed doesnt match that even of IDE. But it s better to be futureproof. Go SATA
16-05-2008, 02:41 AM
GaurishSharma.com
SATA.
IDE is dead now
16-05-2008, 02:42 AM
TechTin.com
Always SATA
16-05-2008, 03:17 AM
I Always Prefer 1080p
If I were you, I would go for External DVD Writer. Lite-On would have been my choice
16-05-2008, 06:56 AM
The Thread Killer >:)
If you would port your drive b/w your system and other systems, for example, your friend's and he doesn't have a SATA port, then it might be a problem. I faced this kind of situation numerous times, so opted for IDE. If porting the drive is not a problem, go for SATA.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
16-05-2008, 07:12 AM
If the prices aren’t much different, I would definitely go with SATA. The cables are smaller and easier to manage, SATA allows for hotswapping (if you ever care to do that), and it’s apparently faster (though I don’t really notice too much of a difference myself).
16-05-2008, 12:21 PM
Evolving Rapidly...
thanks all.
will go to lamington road again tomorrow.
wont it cost more? plus i dont want many things lying around on my desktop...
Reason: Automerged Doublepost
16-05-2008, 01:19 PM
Point Blanc
thanks all.
well the price of liteon extenal is around 1800 and I had checked LG external(Star Bazzar bangalore) priced exactly 2K. Both are 20x writers Lightscribe.
In local market they are pricing LG one as 3500 bucks.
16-05-2008, 01:36 PM
Bond, Desi Bond!
Stay away from liteon drives and LG drives.
Get one that is priced lower (sata vs ide). No noticeable difference between the two except for the data cable. For no clutter inside desktop, you can go for sata.
16-05-2008, 02:10 PM
I M A *STAR*
Go with SATA only.
17-05-2008, 01:08 AM
Point Blanc
I support desibond on this, SATA or IDE doesnt affects much, both have same builds, let see if they have more internal buffer then only its helpful, will better read/write speed. SATA will just save space.
I and I was just teling the price ofexternal burners, I really do not know how good liteon or LG are, used Sony mostly or Samsung.
