Old 15-05-2008, 08:33 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Question Why is my Processor overheating???
Hi,
I just built a new PC. The processor is Intel Dual Core E2180.
I assembled it from scratch. In starting it shows PC Health Status as
CPU temp = 57 degree C .
System Temp= 36 degree C.
I also applied thermal paste on the processor but still the temp is not normal. The fan is also running fine. What would be the problem??
Or is this the normal temp???
Plz help me.
Blogging at:
Technostarry
saqib_khan is offline
Old 15-05-2008, 08:37 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: Why is my Processor overheating???
^^57C is fine for the processor.
But if you want to reduce the temperature more, then clear the dust from the fan blades and the heat sink of the processor.
Add additional fans in your cabinet and make way for proper air flow.
http://twitter.com/akshayms
nvidia is offline
Old 15-05-2008, 09:02 PM   #3 (permalink)
Google Bot
Pathik's Avatar
What paste did you use? Did you apply it properly?
Pathik is offline
Old 15-05-2008, 10:39 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
There is no dust. It is a new box pack processor. I opened the seal tomorrow only .
My dealer said that 57 C is much more for processor & u r saying it is normal??
@Pathik
I used a paste named "Heat sink compound" .This label is on the bottle itself.
Am i using right paste??
I applied this on the processor.
Blogging at:
Technostarry
Old 15-05-2008, 10:55 PM   #5 (permalink)
57 degrees is very high,
Is your cabby well ventilated?
Xccentricity is offline
Old 15-05-2008, 11:01 PM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
Even in case open from 1 side it shows this temp.
Blogging at:
Technostarry
Old 15-05-2008, 11:11 PM   #7 (permalink)
Really peculiar problem,
Use Arctic Silver 5 thermal compound and disable Smart Fan control in your BIOS so that the CPU fan runs at full speed always,
This may be silly but maybe the CPU fan isn't in the proper position or something .
Old 16-05-2008, 12:00 AM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
why did u apply this paste?Intel supplies the HSF with thermal pads on the bottom whihc does a pretty good job.it cud be that u hav applied xcess of thermal paste.clean it off and the apply a fresh thin film of thermal paste.
hellgate is offline
Old 16-05-2008, 12:34 AM   #9 (permalink)
Seed is the Life!!
shift's Avatar
What abot this one http://www.thinkdigit.com/forum/showthread.php?t=87114
What about this one http://www.thinkdigit.com/forum/showthread.php?t=87114
Stupidity Causes Cancer !!
shift is offline
Old 16-05-2008, 10:16 AM   #10 (permalink)
rameeze's Avatar
57 is not normal temp but ur pc can work on it but it can reduce life of system. I have also faced same problem .my pc was working on 60 degree after some time temp reacched toabout 105 and pc shut down. I applied thermal paste and it is working fine on 42-44 degree.
chech if there is any gap between processor and heatsink or whether heatsink is properly fitted or not.
rameeze is offline
Old 16-05-2008, 10:33 AM   #11 (permalink)
ionicsachin's Avatar
57C without overclock is too high....i think the thermal paste is crappy....u know sometimes if ur mobo BIOS is old u get wrong temperature....so after shutting down unplug the main power, touch the PSU(to remove static charge) and then touch the heat sink and see if it is really 57C...i am telling so coz ur system temp is relatively very low....
if it is really high then buy Arctic Silver 5 thermal compound available for some 260bucks at lynx-india....coz most probably ur thermal paste is odd....
my CPU temp before was 40 ideal and 48-50 when playing Crysis......after applying Arctic Silver 5 it is around 35-36 ideal and 45 when playing crysis....
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
ionicsachin is offline
Old 16-05-2008, 11:12 AM   #12 (permalink)
check the cpu voltages, in bios, then post, so that many members can suggest u.
gcbeldar is offline
Old 16-05-2008, 11:22 AM   #13 (permalink)
dhanusaud's Avatar
yeah pal, chech the cpu voltage setting in bios.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 16-05-2008, 11:39 AM   #14 (permalink)
channabasanna's Avatar
What about the compound which comes with the Processor fan which comes with the porcessor. I haven applied any paste for my rig. Pls find my rig in my signature, even normal temperatures would be 51C.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 16-05-2008, 11:39 AM   #15 (permalink)
I M A *STAR*
saqib_khan's Avatar
@hellgate
First i didn't applied any thermal paste, in that situation it was 76 degree C.
And then my dealer said to apply thermal paste, and then the temp went to 57 degree C.
OK, wait for me to post the CPU voltage .
Blogging at:
Technostarry
Old 16-05-2008, 12:10 PM   #16 (permalink)
First i used to think that Thermal Pastes are for high-ends....but later realised that one shudnt run a proccy without thermal paste...t
My first song
Old 16-05-2008, 01:55 PM   #17 (permalink)
I M A *STAR*
saqib_khan's Avatar
Ok, here r the CPU voltages in my BIOS.
Vcore 1.30V
NB 1.39V
+5V 5.28V
+12V 12.14V
5VSB 5.07V
VDIMM 1.92V
3.3 VSB 3.42V
Val Battery 3.16V
And here r the temp's i get by using software named "Speedfan".
Temp1 45 C
Temp2 36 C
Temp3 37 C
HDO 37 C
Temp1 40 C
Core0 46 C
Core1 46 C
So, my question is y BIOS is showing more value, compared to speedfan???
Which is correct, shud i trust BIOS or Speedfan????
Blogging at:
Technostarry
Old 16-05-2008, 02:50 PM   #18 (permalink)
Try another tool and see which 2 of the temperatures tally.
Old 16-05-2008, 03:22 PM   #19 (permalink)
Roadripper's Avatar
I think thermal paste is nt applied properly ... take care u don apply more nor too less...
Roadripper is offline
Old 16-05-2008, 03:25 PM   #20 (permalink)
I M A *STAR*
saqib_khan's Avatar
Nice idea rahul, will try it now.
I will try Hmonitor now.
Got the problem.
Guess what??
When i opened the processor socket & removed the processor, some pins in the mobo were bent. I made them stand straight. And then connected HSF.
Now, the problem is gone. The temp remains around 40 C now.
But i thank u all guys for helping me.
Blogging at:
Technostarry
overheating or something else? fastc0der Hardware Q&A 5 25-09-2007 09:17 PM
cpu overheating The SHARK Hardware Q&A 1 06-03-2007 06:18 PM
Tried Everything Still Overheating!!! ashishkhetriwal Hardware Q&A 1 17-06-2006 02:32 AM
IS it OVERHEATING??? ashishkhetriwal Hardware Q&A 4 02-05-2006 10:54 AM
Processor overheating ak24 QnA (read only) 14 26-08-2005 03:47 PM
- by c4u
