Old 15-05-2008, 08:15 PM   #1 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default creative SBS560 5.1 sound issue!
I recently bought the above mentioned speakers but when i connect it to my on board sound ports the rear ones give very low sound but if i swap the rear with the front ones they work normal so i guess my rear sound port is at fault.am i right??
Secondly if im right then should i go for a 5.1 sound card?if yes which one and how much it would cost?
bump...
anyone????please ans....
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 18-05-2008, 02:57 PM   #2 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
Default Re: creative SBS560 5.1 sound issue!
sum1 please ans...
Old 18-05-2008, 07:19 PM   #3 (permalink)
dhanusaud's Avatar
Mate,
No need to buy snd card as well. . . . . .bcz ur snd card is working fantastic.
Make sure dat audio jack is plugged on properly to green port of ur system's main board.
Anyway wht is ur mainboard's config?
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 19-05-2008, 11:12 AM   #4 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
i did make sure that the pin is jacked properly in the sound port.but no avail.the sound of those rear speakers at times vanishes after reboot.my mobo is VIA 845 RZ.intel celeron 1.7ghz.(i know i live in stone age )
Old 19-05-2008, 03:24 PM   #5 (permalink)
dhanusaud's Avatar
hehehe....u sud hv gud sound card then....
confirm some stores if they have AuzenTech - Prelude X-Fi or get cards from creative labs as well..
Old 20-05-2008, 08:29 PM   #6 (permalink)
i had the same prob with creative m4500. but my mobo has a realtek allc88 sound device, the realtek driver and control panel had settings to increase the rear speaker volumes and now it works great
kooki is offline
Old 21-05-2008, 01:47 AM   #7 (permalink)
5.1 upmixing is suppose to work like that ...all speakers dont have the same level of sound .....rear speakers are just there to give depth to the sound... and they r not low ....they are playing just some part of the sound wavelength.......so ur soundcard is fine ...
allmighty is offline
Old 27-05-2008, 04:42 PM   #8 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
dear allmighty u mean they are supposed to be like that only???
Old 27-05-2008, 04:50 PM   #9 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
yes.
the extra speakers are for effects, not main audio.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 27-05-2008, 05:11 PM   #10 (permalink)
dOm1naTOr's Avatar
Try some games life 2[if u have at least an FX card]. It has fot fantastic effects for surround.
BTW, the onboard sound of 845 is bit too outdated nd below avg performance. U can get a 5.1 sound card from cheap brands like Intex, Enter etc for less than 500/-. They ll get the job done with mostly C-Media 8738 chip. U can also get Creative SB 5.1 card for 1.1k which is recommended.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 28-05-2008, 07:44 PM   #11 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
wat are the advantages of a adon 5.1 sound card over on board one??
Old 28-05-2008, 07:53 PM   #12 (permalink)
dOm1naTOr's Avatar
A dedicated sound card will have its own sound processor chip, which relieves the processor from doing the sound processing. Also with more rooms for proper ckts, the chip can performs better than on onboard.
The sound quality [ny speaker] will improve marginally but i can just say it might be only better if u go for cards like Intex or Enter.
If u want decent improvement, get atleast a Creative 5.1 sound card for 1k or 5.1 Live 24bit for 500 more. No need of getting a better card than these for an SBS 5.1 set.
G3: XPS M1530 |
FZ 16.
Old 28-05-2008, 08:52 PM   #13 (permalink)
The Smaller Bang
but dedicated sound card is still not a definite nessassary item. I can get better audio quality on my P4 with onboard audio but using PulseAudio software, when compared to some cheap dedicated solutions.
Old 29-05-2008, 09:42 AM   #14 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
okay.thanx a lot guys.
Creative Zen issue genxguy Buying Advice 2 23-03-2008 09:58 AM
My Creative 24Bit creative sound card not working in windows vista.... selvamcbe Software Q&A 2 05-11-2006 12:11 PM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
CREATIVE SOUND BLASTER 5.1 naveen_reloaded QnA (read only) 6 14-01-2006 12:21 PM
- by c4u
