Old 14-05-2008, 05:19 PM   #1 (permalink)
dhanusaud's Avatar
Default Suggest me a gud motherboard
Guys,
Plz suggest me gud motherboard under 3k for Intel PD 2.8 Ghz. My recommend config as follows:
Sud support DDR2
Must hv 16x Slot (For Graphics)
Must hv VGA Connector (Some Motherboard doesn't comes with input VGA connector now a days, I wanna use it if I don't have Graphics Card)
and blabla
Thanks
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 14-05-2008, 05:32 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Suggest me a gud motherboard
XFX 630i ultra. Or a Palit n73v.
Pathik is offline
Old 14-05-2008, 05:54 PM   #3 (permalink)
Bot
Tiger's Avatar
Intel D102GGC
Tiger is offline
Old 14-05-2008, 06:45 PM   #4 (permalink)
dhanusaud's Avatar
Guys, wht do you say about mercury boards....usually I don't like these motherboards but my friend is recommending me.
suggest a gud motherboard fun2sh Hardware Q&A 21 25-11-2007 06:00 PM
Suggest a motherboard catchjaga CPU / Motherboards 3 11-08-2006 11:45 AM
AMD motherboard !!!! Plz suggest sidewinder CPU / Motherboards 17 31-10-2004 09:49 AM
AMD motherboard !!!! Plz suggest sidewinder CPU / Motherboards 1 26-10-2004 12:00 AM
- by c4u
