13-05-2008, 09:36 PM
Evolving Rapidly...
Will two ADSL routers on one phone line (in series) work?
Hi friends.
i have a peculiar problem here. i have two pcs in different rooms of my house. i want to share the same phone line (in series) to connect, two adsl routers, one for each pc.
(why i dont want to setup a lan is because, then both pcs will be interdependent. ie both pcs need to be on while using the 2nd pc)
My question:
Since the ADSL router has an inbuilt spilter, will the 2nd modem be able to connect to the net. OR will the 1st router cutoff signals to the 2nd router even when 1st router is off? (ofcourse only one router can be used at any time)
here is a pic to illustrate what i mean (sorry for the noobish effort) :
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
13-05-2008, 10:06 PM
Alter Bridge=GOD
Re: Will two ADSL routers on one phone line (in series) work?
when using lan , both pc's need not to be on , if using a switch / hub
better get that..
i dont think 2nd router can connect when the first is on.
the best way to do this is via a switch / hub..better get netgear 5port switch
Apple Macbook Pro 17 :cool:
13-05-2008, 11:01 PM
Evolving Rapidly...
better get that..
how much will it cost? and any similar devices in the market?
the problem it that the pcs are in different rooms. it will be difficult, when every time u need to switch on/off the modem , u have to go to another room.
that i know. i said, will it be possible to use 2nd router, when 1st router is off?
14-05-2008, 07:08 AM
Alter Bridge=GOD
well proper setup---
1. a switch - netgear 8 port switch cost me 1k , so 5 port would be cheap. other switches should be avoided due to poor AC Adaptors which u cant run 24/7
2. connect ur ADSL modem to switch and both the PC's too.CAT5 works perfect
3.you only need ur modem and switch to be on for accessing internet on any pc.u can shutdown the other pc
this is what u shud do if u have not bought other modem.otherwise ur setup will also work--2nd modem will connect if the first is off .
btw--do u connect urself using a dialer or its automated?
14-05-2008, 09:30 AM
TechTin.com
remember to use straight climped LAN wire.
14-05-2008, 11:47 AM
Evolving Rapidly...
ok. understood. thanks.
i have not bought 2nd modem yet.
i have configured a connection which is always on (using details provided by MTNL). so i just switch on router, wait for the first three lights to come on(power,adsl,pppoe), then just enable the connection.
one doubt:so to use the switch, what changes will i have to make in the connection properties? (i mean, initially the pc connects to the router's ip. but now the pc connects to the switch.)
14-05-2008, 12:10 PM
Alter Bridge=GOD
No changes at all.just plug everything and use it.don't change any setting
14-05-2008, 12:32 PM
Evolving Rapidly...
ok.
16-05-2008, 12:37 AM
Evolving Rapidly...
bought the 8 port netgear switch. for 750 bucks.
tried with one pc, working. will soon try it for both the pcs.......
16-05-2008, 09:10 AM
Alter Bridge=GOD
cool.great price..is it FS 608 V2 ?
16-05-2008, 12:16 PM
Evolving Rapidly...
^^yes.
working with both simultaneously.
thanks nish.
btw - the adapter is GIGANTIC. it dwarfs all other adapters i have.
16-05-2008, 01:25 PM
Point Blanc
+1 for a 5 port switch(around 500 I bought by company named TP-Link), and if you wanna make things real crazy, but a wireless router(less than 2K, you can also take it from your net provider, I am using BSNL provided wireless router) heehe. In SP Road bangalore there is no 5 port switch from D-Link or netgear.
But not a problem when you got your problem resolved which I see from your post.
16-05-2008, 04:38 PM
Evolving Rapidly...
^^but then i will have to safeguard the network, about which i know very less.
so not going through all that trouble.
and yeah i will have to spend a lot more too.
17-05-2008, 04:41 AM
Point Blanc
well, you can safeguard your small network easily. First thing you keep in mind the range of your router second keep it password protected.
Only systems which have the pass can connect to the network. Thats how it works.
Also you can manage your router the same way you manage your normal ethernet router.
