Old 13-05-2008, 04:48 PM   #1 (permalink)
Obsessed with Technology
Default Side panel Fans Air flow
In which direction should the air flow from the 2 fans which i have at the side of my cabinet.
Whether they should suck air from inside of cabinet or blow air inside the cabinet
And i also have a powersupply fan at the back of my cabinet which blows air outside
AMD Athlon 64 X2 Dual Core Processor 4200+ 2.19 GHz, 2.5 GB Ram, 120 GB Hard Disk, XFX 8600GT
Visit my blog devrathnd.blogspot.com
Devrath_ND is offline
Old 13-05-2008, 06:03 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Side panel Fans Air flow
anti *lo*kwise...*ool air m*st be s*pplied to *hasis.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 13-05-2008, 06:09 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
front and side fans-blow air inside
rear fan-exha*st
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 13-05-2008, 08:15 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
yeah, set all fans as said above.
Also If yo*r *abby has provision to fix a top fan set it to exha*st
and if yo* have a very large side fan say 200*m than set it to s**k *ool air inside
and set all fans to exha*st in*l*ding front fan.
I've read that on some iss*e of digit - jan 2007 may be.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Cabinet/Case Fans - Direction of Air Flow janitha QnA (read only) 8 29-01-2006 09:46 PM
Deskloops v1.21 Beta, windows are aligned side by side rajat22 Software Q&A 8 14-11-2005 12:44 AM
Server side & client side languages Trinity Programming 1 05-07-2005 10:50 AM
Traffic flow on dial up shefzomania QnA (read only) 6 03-07-2005 12:44 PM
Can norton and avg exist side by side on one system? rohanbee Software Q&A 15 28-11-2004 01:07 PM
- by c4u
