Old 13-05-2008, 01:57 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default will APC 500/650VA UPS suit my system?
Need to buy an UPS
My system config is:
amd X2 5600+
mobo: asus m2n-e sli
WD 250 gb sata 2 hdd
Lite-On dvd-rw 20X sata2
nvidia geforce 8600gt 256mb ddr3
powersafe 400w psu
i have an adsl modem, speakers n a 15 inch monitor
i intend to upgrade my monitor to 17/19 inch lcd sumtime in the future
i need to buy an ups....i've seen 2 models by apc...500va and 650 va
which one would be able to provide me abt atleast 5 mins of runtime after any power failure?
iceman87 is offline
Old 13-05-2008, 08:36 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: will APC 500/650VA UPS suit my system?
for the above config I'll suggest you to get a 650-800VA ups from brand like apc..
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 14-05-2008, 07:56 AM   #3 (permalink)
if u are planning to buy TFT/LCD monitor u should go for 800W (not VA) UPS
longlife is offline
Old 14-05-2008, 09:06 AM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
I 'de rather suggest Online UPS/Inverter. Dude it might cost u more but it will run every single appliance u need. U can run ur system for hours and many more.
If u still want to invest in UPS then 600VA atleast.
keith_j_snyder2 is offline
Old 14-05-2008, 11:32 AM   #5 (permalink)
better to go for 800VA/1.5 = 530W (approx) if i m not wrong...
i made a mistake of buying a lower VA one and then have to upgrade to 800VA as power requirement rises...but actually since your powersupply is only 400W, 650VA or even 500VA will do for now, then you have to buy another one if you upgrade
in normal operation, the PC any way do not use full 400W
realdan is offline
Old 15-05-2008, 07:54 AM   #6 (permalink)
thanks for those replies....
if i'm running good on a 400W psu....then cd t mean that...i can easily suffice by having 400*1.5=600VA ups?(so the 650VA one looks pretty safe)
anyways...thank u all for ur replies
iceman87 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/87721-will-apc-500-650va-ups-suit-my-system.html
will APC 500 650VA UPS suit my system Hardware Troubleshooting Question This thread Refback 05-07-2010 12:00 PM
like nokia pc suit ismart Mobiles and Tablets 6 16-01-2009 11:52 PM
Not able to connect to net via PC suit rameeze Software Q&A 26 27-04-2008 12:55 PM
Motorola L7 Pc Suit we4net Mobiles and Tablets 1 12-07-2007 03:33 PM
500VA or 650VA UPS? blackpearl Hardware Q&A 31 16-06-2007 12:44 PM
Which AV will best suit my needs? MenTaLLyMenTaL QnA (read only) 42 27-12-2005 12:08 AM
- by c4u
