Old 13-05-2008, 09:24 AM   #1 (permalink)
dhanusaud's Avatar
Default P3 Mthbrd Prob.....
Hello Guys,
My neighbour has P3 system, just for his kid. yesterday he changed cabinet but now it doesn't boots up....i mean no power supply at all. I checked all da connectors, found well as they sud be, I myself replugged them but no power supply when I press power button.
guys, wht sud be da prob?????????
his system config is:
PIII 700Mhz
256MB SDRAM
40GB HDD
Smg DVD+R
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 13-05-2008, 12:26 PM   #2 (permalink)
Default Re: P3 Mthbrd Prob.....
tell ur neighb to chec if mb put in cab proper
tht means no shortin with the cab. make sure them scrw is proper screwed
realdan is offline
Old 13-05-2008, 12:39 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
See if the RAM is connected properly. try reinserting the RAM by changing the slots.
http://twitter.com/akshayms
nvidia is offline
Old 13-05-2008, 02:17 PM   #4 (permalink)
dhanusaud's Avatar
guys, i hv tried a lot as described above but nothing happens....I replugged all the connectors but I failed....
my neighbour thinks that I m genius in computers but I m now myself proving the foolishness.
Old 14-05-2008, 12:54 PM   #5 (permalink)
i think the old pc doesnt like the new cabinet and so refused to stay there
you might want to take a look at the power switch connector which is connected to the motherboard...that might not be connected properly...consult motherboard manual...or connect it the other way around...
realdan is offline
Old 15-05-2008, 12:45 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
@dhanusaud ..... aisa hi hota hai ...... ideas work 4 ur pc only & public pc`s just refuse 2 co-operate ......
happened with me 2, everytime ijat ka kachara .... so now i have stopped visit ppl 2 help in their pc problems ......
... W H O T ...
ax3 is offline
Old 15-05-2008, 03:55 PM   #7 (permalink)
dhanusaud's Avatar
Really I respect your comment.
Last sunday, my friend called to see his HP Presario Desktop PC. Damn...wht a hell he have maintained his system. PS2 connector for mouse was completely damaged & he said to setup XP SP2 in his system. Okay I did it but without mouse system was useless for him. Oohh..I forgot about USB Mouse....now his problem is solved by USB Mouse...thank god, izzat ka faluda ho jata.
Anyway, guys I said my neighbour to upgrade system. He will manage for the same soon.
Old 15-05-2008, 08:05 PM   #8 (permalink)
Ranjya's Avatar
This new cabinet you are using will not have P-3 ATX power supply.
Use new cabinet but old power supply.
It could even be a AT power supply (Rarely)
Things will work then.
Even i tried a ATX P-3 PSU on My AT mobo with ATX connector
refused to power on.
Try the Old PSU.
Ranjya is offline
Old 15-05-2008, 10:59 PM   #9 (permalink)
What is the mobo manufacturer and chipset?
Maybe you've connected the Power-Switch wire to the wrong place or something like this.
Xccentricity is offline
Old 16-05-2008, 09:49 AM   #10 (permalink)
dhanusaud's Avatar
Mate,
I m hardware engineer, why sud I do minor stupdity. I looked deeply yesterday...found board was cracked. I mean my neighbour has applied his energy formula, while mounting in new cabinet.
Old 16-05-2008, 04:38 PM   #11 (permalink)
ax3
ax3's Avatar
hai la .....
these mb`s r very delicate ...... i just freakout while handeling them ..... coz any small gaadbad then u endup paying more 4 repairs ......
so thats y i have stopped handeling ppl`s pc internal .... khali peeli aapne par ? aata hai & public blame karne ko ready rehate hai .......
... W H O T ...
ax3 is offline
Old 16-05-2008, 04:49 PM   #12 (permalink)
dhanusaud's Avatar
hai la .....
i agree.. but I can't stop repairng public coms..
Old 16-05-2008, 06:46 PM   #13 (permalink)
@dhanusaud
Well atleast now maybe you're neighbor will upgrade his PC ,
Well the so call "hardware engineers" who came to install my friends PC put a jumper in the wrong place and screwed up the whole mobo, even in the case of experts anythings possible dude .
Old 17-05-2008, 04:47 AM   #14 (permalink)
Point Blanc
well if he says he is a hardware engineer it certainly would mean something he is not a self learned mechanic I think, heehe.
dhanusaud you realized things quickly, that your neighbour is a muscle for hire, I think.
acewin is offline
Old 17-05-2008, 07:41 AM   #15 (permalink)
dhanusaud's Avatar
@dhanusaud
I agree with you pal but regarding connectors i m expert. Rest i m not expert but i m too gud instead.
Old 17-05-2008, 02:46 PM   #16 (permalink)
Once I helped my friend install some software, his HDD already had some bad sectors and he got a BSOD and he blamed me for ruining his OS! .
Old 17-05-2008, 02:52 PM   #17 (permalink)
did you check the power supply, see whether it works or not. connect one black power point to the green one and see whether the fan moves. if it does the ps is ok or else it is kaput
meghdut is offline
Old 17-05-2008, 03:02 PM   #18 (permalink)
dhanusaud's Avatar
yeah mate,
sometime it happens. whenever you say the fact, user don't believe us, instead they blame us.
buddy,
you sud scroll above, I hv already said board is cracked...
HDD prob fannedman Hardware Q&A 3 26-02-2007 03:42 PM
IE Prob spynic Software Q&A 1 11-02-2007 10:21 PM
Plz Help!! Prob With Asp!! evil_maverick Software Q&A 1 05-02-2007 10:52 AM
Prob... Prob... Prob.... kool QnA (read only) 2 18-07-2006 08:57 PM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
- by c4u
