Need suggestion's regarding the best upgrade possible for a budget of Rs.3000
I mostly use my com to play games & use Flash pro. & Google Sketch.
[Low res. of 800*600 is OK for playing games]
My current config is:
AMD Sempron 2500+ (1.41 Ghz)
960 MB of DDR1 RAM
64MB Shared Memory
VIA/S3G Unichrome Pro IGPDisplay Drive(Does not support most of the games)
Gigabyte AGP8X motherbard(Support AGP Card)
you might want to search the second hand market for a graphics card..even if you get one for as cheap a price...your pc will soon pass away becos the additional strain on the power supply will suffocate the other components and make sure that they will die
