Old 11-05-2008, 05:38 PM   #1 (permalink)
Default one long beep 2 short beeps
my old pc
amd 64 3200+ 939
asus a8n-sli pe
7600gt
1gb ddr400 kingston
antec sp-400w
bought 2006
today suddenly while it was running, one long beep and two short beep was emitting from the PC continuously...no display
removing graphics cards and reseating it have the same beeps codes
try with a spare 6600gt..same beep codes
graphics card 7600gt works in another PC..
removed all memory..same beep codes
try with different combo of the memory and memory slots to of no avail
removed the processor...re-install it back...same
so looks like it is a motherboard problem right?
realdan is offline
Old 11-05-2008, 06:33 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: one long beep 2 short beeps
make sure RAM is seated properly in its slot.
praka123 is offline
Old 11-05-2008, 06:48 PM   #3 (permalink)
dOm1naTOr's Avatar
There is some problem with the video interface on ur mobo. Thats wat the long nd 2 short beeps mean. And as u are sure the card is ok, then surelly the mobos PCIE interface has some trouble.
Get it replaced if its still in warranty.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-05-2008, 12:43 AM   #4 (permalink)
it is ram problem no doubt it,insert the ram properly and remove and re insert the processorrrrrrrrrrrrrr
duggi_raju is offline
Old 12-05-2008, 01:10 AM   #5 (permalink)
well the retail box of the motherboard said, "3 years" so it may still be in warranty...bought in 11th aug 2006
i have reseat memory, and processors to of no avail..i dont have similar system to check the memory and processor...but removing all memory also have the same error beep codes...it is as if I didnt installed the graphics card...and by the way all the fans are spinning including that of the graphics card...
so i can take it to rashi? sticker on motherboard show rashi name
http://in.asus.com/aboutasus.aspx?show=5
Authorized Service Provider:
  1. Digicomp is authorize service provider for Motherboard, VGA cards, ODD, Barebones
  2. Rashi Care is authorized for Motherboard service sold by Rashi..
  3. Pacific Infotech will do the service for Servers and Networking Products.
  4. ASUS RC is authorized service provider for Handset product.
realdan is offline
Old 20-06-2008, 10:44 AM   #6 (permalink)
¦Rage--oצ's Avatar
One long and two short beeps mean that thers a prob wid ur graphic card!!as u said the graphic card works on other comp. den surely ur MOTHERBOARD IS FAULTY.. give it fr repair or buy a new 1 !!!!
¦Rage--oצ is offline
Old 20-06-2008, 05:53 PM   #7 (permalink)
TheSaint
NucleusKore's Avatar
Read
http://www.pchell.com/hardware/beepcodes.shtml
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 25-06-2008, 03:13 PM   #8 (permalink)
sorry guys didnt post back the end result of it all..one guy asked me so i was reminded that i didnt post the end result here..
well it turns out two memory slots in channel 1 has become non-functional...
it is a lapse on my part that i thought i have checked all slots
this was after i took it to rashi and they said nothing wrong and showed me it is booting..damn..nope they didnt tell me anything about memory slot issue..it was the two slots near the processor that turn out to be faulty..do you think under warranty they should have replaced it or got it repaired...
then i didnt went back...
also one of two memory modules is not working...
in conclusion it is
memory problem = 1 module in a pair of it is not working
motherboard problem = two memory slots not working
realdan is offline
Old 25-06-2008, 05:35 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
On monday I faced exct same problem with my old 845 mobo.
After around 12 times sitting two 512MB ram modules properly every thing is back to normal.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 28-06-2008, 04:12 PM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Err.... Sorry....
I've forgotten to mention that I've changed the CMOS battery also.
topgear is offline
Make long URL short - no ads pirates1323 Chit-Chat 3 18-09-2007 06:43 PM
long beep frm a pc-it means RAM s OUT. aaa- guide me pls mobileman Hardware Q&A 12 24-06-2007 10:40 AM
long beeps....booting prob!!! archillies Hardware Q&A 8 13-03-2007 09:56 PM
Computer dosent boot-Cont. short Beeps-Pl. help rahul_becks23 Software Q&A 2 06-01-2005 11:51 AM
Long BIOS beeps deepesh83 QnA (read only) 16 25-08-2004 05:29 PM
- by c4u
