10-05-2008, 04:19 PM
Performance Desktop for 80,000 INR
I will be getting a new PC in August. Been doing a lot of homework over the last month. The budget is 80,000 INR. Here's what I have so far... I'd appreciate some feedback
CPU: Intel Core2 Duo E8400
Figured it's too early to go quad. the 8400 offers pretty similar performance to the top of the line 8500 at around Rs. 3,500 lesser. Sensible buy, methinks.
Motherboard: Waiting for the new mainstream P45 based boards with PCIe 2.0 support. There are previews of a bunch of upcoming releases all over the internet. Yet to decided the specifics. I'm going DDR2. Crossfire/SLI support isn't a concern for me. Overclockability is. I'm planning on putting my E8400 through some pretty tough rigours.
Graphics: GeForce 8800GT. The OVERCLOCKED Gigabyte card with the Zalman cooler seems like a lock at 12,000 INR. I've read a buncha reviews of the same and the opinions are unanimously in favour of this card. Will post specs if necessary.
RAM: 2X1GB High frequency, Low latency. Again, yet to decide the specifics. Suggestions, folks?
HDD: 500GB Seagate Barracuda/WD Caviar. They both retail for around 5,000 INR. Decent buys.
Monitor: 19" Widescreen. The new Samsung touch series seems yummy. I'm hoping the price drops to around 10k by August.
Gamepad: Logitech Rumblepad 2. Rs. 2,000 aprx.
I know there's a lot still missing, namely... PSU, Cooling, Case, Optical Drive, Speakers, Headphones, Keyboard, Mouse and UPS. I've intentionally left quite a lot of budget space for the remaining components. Not very certain of how costly they would turn out to be. Should be within 80,000 though.
I will be updating this post with the new components once I've done enough digging. Please do check back often. Later
10-05-2008, 04:22 PM
Juke Box Hero
Re: Performance Desktop for 80,000 INR
Originally Posted by depolo08
Please do check back often. And it's great to be here on Tech2. Later...
Say again?!
10-05-2008, 04:26 PM
For the given specs, I think 2x1GB may be a bottleneck... Perhaps you can go for 2x2GB?
Arun
10-05-2008, 04:48 PM
Evolving Rapidly...
Originally Posted by Hitboxx
Say again?!
+1
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
10-05-2008, 07:06 PM
i will answer all that first answer me which type of PC are you making gaming or entertainment etc & do you plan to OC or not?
10-05-2008, 07:16 PM
=--=l33t=--=
Very Nice config. However, it's not too early to go quad  I would suggest getting a quad purely because its going to be a lot more future-proof. If youre spending close to a lakh on something, it really should last you a while.
The 8800GT may be nice, but I recommend a Series9 Card. For DX 10.1. That .1 might prove to be extremely pissing off later on.
The RAM is hardly a bottleneck. You definetly want to get something better than a Transcend though. OCing without unlocked multis is not going to be easy with bad RAM.
If there is a bottleneck, then it's your HDD. At least 2 Disks in RAID0 is mandatory.
You are also going to want to get a CPU cooler. Get A ThermalTake cooler with Arctic Fans.
Homer: God bless those pagans.
10-05-2008, 07:17 PM
I posted the same at the tech 2 forums thinkin i'd get as much input as possible. Moving on... The computer i'm building is gaming oriented. I'm not sure what the differences would be though excepting the peripherals. And yes, i do plan on overclocking.
10-05-2008, 07:36 PM
CPU E8400 is good choose
MB go for abit IP35-e
GF consider 9800GTX or 9800GX2
Ram Corsair XMS2 4GB 800Mhz = 6500
PSU = this is final componet of the computer & so i will answer that when all your other computer componets are selected
CPU fan CM Hyper TX2 = 1700
Case CM690 = around 4.5k or Antec 900 = around 7k (choose acc to your needs)
Optical drive Samsung Sh203-b = 1200
Keyboard Logitech G15 = 4.5k
Mouse Logitech MX518 = 1200
10-05-2008, 07:42 PM
Alter Bridge=GOD
Q6600 with ultima 90i or 120extreme
msi p7n sli
2*8800gt in sli
4gb corsair or gskill ram
western digital 750gb hdd
dell or samsung 19/22inch tft
corsair 620hx
cooler master case
Apple Macbook Pro 17 :cool:
10-05-2008, 07:43 PM
Evolving Rapidly...
which model are u talking about here? is it this one? (i want to verify price)
10-05-2008, 08:03 PM
No bro that is DHX it costs more i am talking abt normal XMS2. This one http://www.corsair.com/_datasheets/TWIN2X2048-6400.pdf
now i have to go. i had to watch IPL
10-05-2008, 08:16 PM
Evolving Rapidly...
what is the avg street price for DHX?
10-05-2008, 08:33 PM
For that budget, going for 8800 ultra or 2 8800 GT in sli would be a good choice. however, you might not need that power. Make sure you buy a good display.
10-05-2008, 09:00 PM
Evolving Rapidly...
@threadstarter - HDD is not 5k, its more like 4k.
10-05-2008, 10:13 PM
Living to Succeed
ITwares quote around 6800 for the same ram... please confirm in the shop
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
11-05-2008, 12:51 AM
@depolo,
what!!! One same thread on two different forums?
Anyways, u got reply on one!
11-05-2008, 08:14 AM
bro r u sure that 4gb of DHX is at 6800?????????
as far i know 4gb of DHX should cost upward of 7600.
11-05-2008, 10:05 AM
FYI, Geforce 9 series is only DX10 compliant and not DX10.1, its the ATI HD38xx series that is DX10.1 compliant.Proof of this, the entire Geforce 9 series is based on G92,the same core found in 8800GT and 8800GTS 512MB.
Before recommending RAID 0, i guess its necessary to beware users of the risks involved with setting up RAID 0 setup.
I wouldnt recommend a Thermaltake cooler.Thermalright Ultra 120 Extreme is one of the best cooler with very good VFM.
P45 isnt going to offer anything out of this world in terms of 45nm Dual Core overclocking. It would be a good decision to get a good P35 board too which can do 550+ FSB.If you can wait, then its fine going for P45 but the boards wont be cheap either.
11-05-2008, 10:06 AM
#19 (permalink)
Evolving Rapidly...
i think u mean CAS5 costs 6800. CAS4 about which me and blackfire are talking is costing upwards of 7k.
11-05-2008, 11:35 AM
#20 (permalink)
Alright, let me say this once and for all  I realise that spending more money doesn't automatically guarantee better performance. I'm looking for a good ratio. If I can wrap up all that I need within a very comfy 65-70k, that would be great. Thank you for reading.
I believe that getting more performance out of the applications available right now is more important that sitting on eggs for another 2 years. Quad core is arguably still in it's toddler phase. I'll go for a quad core solution when I upgrade/build a new rig.
As someone pointed out, the 9 series cards don't support DX10.1 either. 8800GT it is.
Do recommend a nice set of 2X1GB RAM's.
I did a quick check on RAID 0. What are the real world benefits and risks? Also, would it be ok if I just got a couple of 250GB disks and ran them in RAID 0?
Someone suggested the LEXA Blackline cabinet. It does seem better than the CM690. Ideally, I'd be looking for some good property hovering around the 5K mark.
I'm getting an Intel chipset based board, so SLI isn't an option. How much does the ultra cost?
I quoted the prices from this month's Digit mag.
I've had my eyes on that one for a while. How much does it retail for in India?
PCIe 2.0 and official FSB 1600 support. It is future proof. Overclockability should be better than the P35 based boards. I plan on taking the E8400 to close to 4GHz on air. And yes, I'm fine with waiting. I'm getting the comp only in August. There should be a few P45 based boards doing the rounds by then.
Now, people, answer me these please
How much power supply would I need with the stated config and my overclockability demands? Would 650W be safe?
What are good available options when it comes to 2.1 speakers? I don't want to overspend.
Headphones... good brands? Heard Sennheiser has a decent range. 1-1.5k budget.
What are the good UPS brands? How much would one that suits my requirements cost?
11-05-2008, 11:48 AM
#21 (permalink)
If u intend on buying only in August, then look out for ATI's HD 4870. As per some leaked benchs it even beats 9800GX2 and it wont be dat expensive.
U can also look for HD 3870 X2 which is the second most powerful card now after 9800GX2 nd is priced at a sweet 20~21k.
Corsair HX 620 wud be enough for ur rig. Its bout 6.5k. U can also look for CM EP650W which is much cheaper at 3.5k~4k. The HX wud be better.
G3: XPS M1530 |
FZ 16.
11-05-2008, 01:23 PM
#22 (permalink)
Guess Who's Back
Raid 0 gives no perfomance boost so don't spend your money there, here is a article that proves the point.
Bottom line: RAID-0 arrays will win you just about any benchmark, but they'll deliver virtually nothing more than that for real world desktop performance. That's just the cold hard truth.
http://www.anandtech.com/storage/sho...px?i=2101&p=11
Stay Hungry. Stay Foolish.
11-05-2008, 01:56 PM
#23 (permalink)
Living to Succeed
Check out www.theitwares.com
11-05-2008, 02:56 PM
#24 (permalink)
is it wares selling these products, if yes than how can i buy it.
11-05-2008, 04:00 PM
#25 (permalink)
Living to Succeed
just go the website... check the price... email them ... ask for a better rate and... or just call them up at the number given on the website
20-12-2009, 10:02 PM
#26 (permalink)
Even i want to set up a gaming rig for the same budget as yours,
i'll want a monitor too, no speakers i,ll prefer just headphones which i have,
no mouse or keyboard.
this is what i have thought of
CPU : INTEL CORE i7 860
GPU : ATI RADEON HD 5850
MOTHERBOARD : HELP
( how about asus rampage ii gene??
overclocking? yep)
CHASIS : CM 690
MONITOR : BENQ G2412HP
PSU : CORSAIR VX550
RAM : (i'll get any 3gb ram mudules from a hardwware store)
COOLING : WHAT'S THAT.
HDD : 250 GB SEAGATE
i will be getting it in the summers so waiting no problem
OS : WINDOWS 7 64 BIT (WE LIVE IN INDIA!)
HELP ME!!!!!!!!!!!!111111
---------- Post added at 10:02 PM ---------- Previous post was at 10:01 PM ----------
MOTHERBOARD : HELP
overclocking? yep)
CHASIS : CM 690
PSU : CORSAIR VX550
