07-05-2008, 11:56 AM
Widescreen vs. Square LCD Monitors
07-05-2008, 12:12 PM
Re: Widescreen vs. Square LCD Monitors
Widescreen..higher resolution, more viewable area...I cant see any advantages of square monitors!
07-05-2008, 12:27 PM
=--=l33t=--=
Compatibility with some old games....
Homer: God bless those pagans.
07-05-2008, 12:59 PM
Square monitors are only for office use...
07-05-2008, 10:05 PM
Widescreens, if you have a new PC (old PCs wont support the resolution).
advantages: cheaper, easily available, better for movies & surfing the net and positioning is more comfortable (that is why movies are widescreen, you don't want to look up)
07-05-2008, 10:34 PM
At Hell's Disq
get a widescreen monitor.they r better for movies and gaming (most new games support widescreen monitor).
workspace is more.
07-05-2008, 11:04 PM
You gave been GXified
Widescreen is prefered, u get so much work space
about.me/gxsaurav
09-05-2008, 09:20 PM
Fast 'N' Furious
I'll vote for widescreen now even if a year ago I've bought sqare LCD as I've loads of old games
widescreen should be perfect for movies, new games, even office works like spreadsheet apps & photoshop.
09-05-2008, 09:36 PM
Legen-wait for it-dary!
+1 for widescreen. Using 19" samsung widescreen myself. Try to get a 30" monitor. 2560x1600 FTW!!!!
09-05-2008, 09:53 PM
+1 to widescreen...lots of place to move around.
09-05-2008, 11:38 PM
At Hell's Disq
once u get the xperience of using a wide monitor u wont wanna use a square one.
12-05-2008, 12:22 PM
Point Blanc
heehe alot much correct, you would wanna go for square monitor upto 17 inches only because with above 19 inches the view area increases so better go for proper monitors which are according to movies or games.
The res of HD movies is 16:9(thats what widescreen are mostly) and not 4:3( square monitors have this dimension ratios )
so
so +1 for 19+ inch widescreen
and +1 for 17 inch square (which I dont think people will go now with such good pricing available for better monitors)
13-05-2008, 12:42 PM
Cool as a CUCUMBAR ! ! !
my vote goes 2 square lcd`s ....
... W H O T ...
13-05-2008, 08:28 PM
Re: Wides*reen vs. Sq*are L*D Monitors
Isn't it possible to r*n the relatively older games in wides*reen monitors at all?
13-05-2008, 08:29 PM
In Pursuit of "Happyness"
I prefer sq*are.. Most pages have verti*al s*rollbars.. Not horizontal s*rollbars.. Verti*al spa*e is more important to me
13-05-2008, 08:54 PM
Wire muncher!
Yes, it is possible with this software, called Universal Widescreen Patcher: http://www.widescreengamingforum.com...iWS.29_Patcher
14-05-2008, 09:46 AM
The Frozen Nova
Widescreen for me. My only glitch is most of my wallpapers are not in the widescreen format.
www.nerdweed.blogspot.com
14-05-2008, 10:02 AM
At Hell's Disq
then either d/l widescreen wallpapers or stretch the normal wallapers to fill the screen.
15-05-2008, 12:47 PM
#19 (permalink)
bt stretch wallpapers look BEKAAR ..... & everything looks STRETCHED ..... that y i support square lcd`s ......
... W H O T ...
17-05-2008, 01:26 AM
#20 (permalink)
Point Blanc
what do you want us to tell sites where you can dload nice widescreen wallpapers.
17-05-2008, 10:01 AM
#21 (permalink)
The Frozen Nova
Yeh, hellgate, like axx0 said stretched wallpapers look bad as the aspect ratio changes. But, with the vista sidebar on one end, now all I have to deal is with the empty space on the left side.
17-05-2008, 09:45 PM
#22 (permalink)
all u guys having trouble with streched wallpapers, do one thing. just go to any torrent site, search for a widescreen wallpaper pack and download it. of course there are other ways too, but this one's quite fast. and in case you r on a limited connexion, get hold of Jun '07 digit dvd, loads of wallpapers over there.
17-05-2008, 10:22 PM
#23 (permalink)
At Hell's Disq
if u stretch a 1024x768 wallpaper to 1440x900 res it looks bad but if u stretch a 1280x1024 or 1280x960 wallpaper it doesnt look that bad.
18-05-2008, 12:46 PM
#24 (permalink)
How can wall papers be a criteria for choosing between a wide screen and square display??
I think games, movies, etc should be a bigger concern. And don't forget, CRT monitors consume loads of power.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
18-05-2008, 06:45 PM
#25 (permalink)
lol...
+1 for Sq*are Ones!!
See, the opinions may vary in accordance to preferences!
18-05-2008, 07:28 PM
#26 (permalink)
My vote goes to widescreen even i hv smsng 17'' tft . . . . . bcz i require lot space for vs 08 as well as photoshop.
Wallpaper isn't serious matter. . .we can every where in net or we can create digital art.
18-05-2008, 08:06 PM
#27 (permalink)
Bond, Desi Bond!
widescreen. Moved from 15" 4:3 display to 19" 16:10 display. Superb for reading ebooks, playing games and watching movies.
05-06-2008, 12:50 PM
#28 (permalink)
Wise Old Crow
Does Intels DG33 motherboard supports widescreen resolutions?
http://twitter.com/blueshift155
05-06-2008, 02:00 PM
#29 (permalink)
At Hell's Disq
^^^ yes it does.
05-06-2008, 04:18 PM
#30 (permalink)
Wise Old Crow
thanks hellgate.
