Old 07-05-2008, 07:59 AM   #1 (permalink)
shashank_re's Avatar
Lightbulb Auzentech Xplosion,are they Worth?
As few members here might be knowing i have purchased Logitech Z-5500 along with my new PC.
At present iam on onboard audio(SPDIF). But i was looking at Auzentech Xplosion 7.1.Its seems to be having interesting features such as DDS live, DTS Connect etc.
What i want to know is ; Is this(Auzentech Xplosion) Soundcard Worth the Money?
Just for info,here goes my new PC config:
E8400 @ 3.0Ghz
Abit IP35-E(It has SPDIF and OPTICAL OUT)
2GB x 1 DDR2 800 Transcend
XFX 9600GT
etc....
So will there be a BIG difference in Audio quality with Auzentech Xplosion over
onboard audio?
All put together: Should i go for it or not?
shashank_re is online now
Old 07-05-2008, 10:56 AM   #2 (permalink)
99.9% Idle
axxo's Avatar
Default Re: Auzentech Xplosion,are they Worth?
anyday a dedicated soundcard outperform onboard sound.
I still use my old day sb live 5.1 value on vista instead of crappy realtek HD audio.
axxo is offline
Old 08-05-2008, 12:12 PM   #3 (permalink)
Finally managed to purchase Auzentech Xplosion 7.1 from one of the member of a Forum(NOT digit) for 3k.
But till now i didnot find any difference between this and my onboard sound
No surround effect feeling itself I have connected using optical cable.
Am i doing anything wrong????!
Old 08-05-2008, 01:18 PM   #4 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Have you configured everything properly via the Sound Card's Control Panel? Have you even chosen the sound card as the source?
Homer: God bless those pagans.
ring_wraith is offline
Old 08-05-2008, 01:59 PM   #5 (permalink)
Thats where i have doubt! The settings are as follows;
System Input: 2 CH
S/PDIF: DTS Interactive
DTS NeoPC: OFF
7.1Virtual Speaker Shift: OFF
Everything else at default.Are these settings correct?
Old 10-05-2008, 01:41 AM   #6 (permalink)
Evolving Rapidly...
confused's Avatar
i read in PCW, sum1 asked a simlar ques. and they said "no dedicated snd card doesnt make a difference".
bcoz nowadays onboard audio itself is very advanced.
i have a intel 815i, and mind you soundblaster makes a huge difference.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 10-05-2008, 02:03 AM   #7 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
they do make a huge difference infact.
get some 5.1 channel movie or audio songs and listen to them,you will feel the difference.Real use is in the games which have inherent 5.1ch\7.1 ch audio.
But you need to have top-quality audio hardware like speakers,headphones,and connectors\wires.this is not a cheap hobby.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Auzentech X-Fi Prelude 7.1 Sound Card temperworld Hardware Q&A 1 26-12-2007 10:27 AM
and worth 15k.....!!!!!! adi87 Buying Advice 10 15-05-2006 02:37 PM
Worth 10k adi87 Buying Advice 28 15-05-2006 10:19 AM
- by c4u
