Old 06-05-2008, 08:48 PM   #1 (permalink)
Default Unable to enter BIOS.
Hi,
I'm unable to enter BIOS, when I hit [DEL] when the PC starts the screen becomes blank and just stays that way,
I even interchanged the RAMs and even tested whether the RAM slots were faulty, I even unplugged the HDD and DVD-RW and completely cleaned my mobo and cabinet but to no avail.
This is my BIOS info:-
BIOS Type: Award Modular BIOS v6.00PG
BIOS ID:   01/31/2000-i810-W83627HF-6A69MPNCC
OEM Sign-On: BIW1B/BIW2B BIOS Ver:1.3
Chipset:   Intel Whitney 82810 rev 3
Superio:   Winbond 627F/HF rev 3 found at port 2Eh
OS:        WinXP SP3
CPU:       Pentium III 700 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size:      256K
Memory Installed:   256 MB
Memory Maximum:     Unknown
Memory Slot 01:     128 MB
Memory Slot 02:     128 MB
Xccentricity is offline
Old 07-05-2008, 02:49 PM   #2 (permalink)
Default Re: Unable to enter BIOS.
Bump!
Old 07-05-2008, 03:10 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
reset ur bios with Clr CMOS jumper or remove that cell and put it again
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 07-05-2008, 08:44 PM   #4 (permalink)
^Tried both the methods, but still I'm facing the same problem.
Old 07-05-2008, 08:51 PM   #5 (permalink)
Amir.php's Avatar
Try to flash Your Bios with latest Update
Amir.php is offline
Old 08-05-2008, 09:22 AM   #6 (permalink)
+1
hsetir is offline
Old 08-05-2008, 12:27 PM   #7 (permalink)
How do I flash my BIOS?
When the PC starts I get an option to flash the BIOS using a floppy, but I dont have a FDD,
Can it be done via Windows XP?
Also I searched google but I couldn't find anything useful, could someone plz give me the link to flash my BIOS(Look at my BIOS stats).
Cant enter CMOS & cant go further return_of_vengeance Software Q&A 6 16-04-2009 07:28 PM
Help.I cant enter into windows mukilan Software Q&A 6 30-08-2007 12:10 AM
How to enter VGA Bios? emailaatif786 QnA (read only) 2 04-08-2007 03:18 PM
Unable to flash bios Vyasram QnA (read only) 10 01-02-2006 06:45 PM
Can't enter BIOS settings...Help!!! linardni QnA (read only) 15 13-01-2006 02:13 PM
- by c4u
