Old 06-05-2008, 09:01 AM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Is C2D T5270 good enough???
i m plannin 2 buy a dell laptop for normal use n casual gamin, with following config:
C2D T5270 (1.4GHz, 800MHz FBS)
2 GB dual channel DDR2
NVIDIA 8600GT 256 MB
160 GB 7200 rpm HDD
Win XP
NOW, i want 2 know will de prosessor bottelneck de GPU?
is it better 2 upgrade to T7250(2.0 GHz) for additional $200, isnt $200 too much 4 de upgrade?
plez help!!!
ankushkool is offline
Old 06-05-2008, 10:19 AM   #2 (permalink)
ankushkool's Avatar
Default Re: Is C2D T5270 good enough???
anyone?
Old 06-05-2008, 10:30 AM   #3 (permalink)
gopz's Avatar
Need help with laptop config.
Why another thread anushkool?
gopz is offline
Old 06-05-2008, 01:36 PM   #4 (permalink)
ankushkool's Avatar
^^wrong section
Old 06-05-2008, 02:38 PM   #5 (permalink)
gopz's Avatar
Mods can move or merge the threads.
gopz is offline
Old 06-05-2008, 09:10 PM   #6 (permalink)
ankushkool's Avatar
anyone!!! plez help
Old 07-05-2008, 11:08 PM   #7 (permalink)
ankushkool's Avatar
need help here!
Old 07-05-2008, 11:46 PM   #8 (permalink)
Google Bot
Pathik's Avatar
Yep. 200$ is too much for the upgrade. They should give atleast a t8100 for that much. Go with the t5270 or 5470
Pathik is offline
Old 07-05-2008, 11:55 PM   #9 (permalink)
dOm1naTOr's Avatar
Get T5550 1.8 Ghz...it wont be much costlier nd gives far better performance.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 08-05-2008, 09:43 AM   #10 (permalink)
ankushkool's Avatar
^^ dell 1500 dosent give that option... 1700 does
also tell me will there be a sufficient improvement in de preformance if i go 4 7200rpm HDD ?
Old 08-05-2008, 10:05 AM   #11 (permalink)
Google Bot
Pathik's Avatar
Yep. There will. Btw if you are getting a vostro, get the newer Vostro 1510
Pathik is offline
Old 11-05-2008, 07:48 PM   #12 (permalink)
ankushkool's Avatar
^^ vostro 1510 does not hav 8600GT it only gives a option of 8400GT.
hey pathik, wont 7200rpm HDD dissipate more heat... i think my laptop is gonna be a oven with 8600GT + 7200rpm... is T5270 cooler than T7250???
Old 19-05-2008, 10:22 AM   #13 (permalink)
ankushkool's Avatar
plez reply
Old 19-05-2008, 08:29 PM   #14 (permalink)
dOm1naTOr's Avatar
@ankushkool
not much diff in heat b/w a 5400 rpm one nd 7200 rpm. Just the vibration will be more, nd battery backup too ll be degraded a bit.
And HDD and the gcard are located on different locations on lappy and actually the heat generated by an M8600GT is way higher than a HDD. GPU temps cud shoot upto 90c.
G3: XPS M1530 |
FZ 16.
Old 19-05-2008, 09:04 PM   #15 (permalink)
ankushkool's Avatar
OMG!!! so whats de sol??? sud i avoid takin 8600 n go 4 8400?
suggestions plezzzz
Old 19-05-2008, 09:49 PM   #16 (permalink)
dOm1naTOr's Avatar
U cant do nythin bout it. But u dun have to worry, coz it dun get unstable even at 90c, nd its just that u cant use the lappy on lap atleast while gamin. just turn on the fans in the room while gaming, and keep the rear end of lappy ventillated whils gamin.
If 90c is ok with the GPU, y shud we care? we just ve to make sure it dun rise evn high due to our mistakes like covering the back of lappy whikle on cushion, bed or somethin. Dell lappy's has gud quality copper heatpipes running thoughout the lappy nd it does its job well. U can go for 8600M GT safely.
BTW, i think Dell provides GDD3 for 8600GT only for XPS models. Just confirm that
G3: XPS M1530 |
FZ 16.
Old 20-05-2008, 09:37 AM   #17 (permalink)
ankushkool's Avatar
Thanx
i wud like 2 know is there any need of external cooling?
Old 20-05-2008, 09:52 AM   #18 (permalink)
Point Blanc
any cooling is good, sit in AC, LOL,
Check this Cooling Pads and external Fans for Laptops
available in India but at what price I do not know.
acewin is offline
any good cheap phone looks like businees phone with good features marriah22 Mobiles and Tablets 3 29-02-2008 12:54 PM
suggest a good tv tuner card with good recording capability NiluGeek Hardware Q&A 1 06-10-2007 08:28 PM
want to purchase Good EDGE enabled handset with good music quality.... mdp Mobiles and Tablets 13 29-09-2007 02:40 AM
Need Good .Net[C# and ASP] e books i googled it but in vain nothing good and easy Sinja Internet & WWW 2 29-09-2006 01:20 AM
- by c4u
