06-05-2008, 12:23 AM
No Display
What to do when there is no display.
06-05-2008, 12:32 AM
Re: No Display
windows repair option is out of question.you better reformat.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
06-05-2008, 11:06 AM
Re: No Display
there should be atleast some clue of what type of problem this is.monitor not working, windows not booting, no display signal, or just set the wrong resolution like someone had posted earlier.
06-05-2008, 11:10 AM
Re: No Display
Check if monitor is dead....check that u r graphic card is seated well and extra powered(if needed)...and of all...check if ur mobo is gettin power and fans are runnin
My first song
http://rapidshare.com/files/128849730/Sachin_-_In_My_Dreams.mp3
http://cid-e2d4f861e716a7fe.skydrive.live.com/self.aspx/.Public/Sachin%20-%20In%20My%20Dreams.mp3
Re: No Display
Elaborate your problem. Monior not turning on or cpu not working?
06-05-2008, 02:20 PM
Evolving Rapidly...
Re: No Display
well, i had a frnd, who had just bought a new rig. he plugged in his vga connector into his onboard port, (although there was a seperate pcie gpu) thinking, the gpu will not work until, the drivers are installed. and he didnt get a signal.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
06-05-2008, 10:52 PM
Re: No Display
Monitor is working but there is no reponse from CPU. Even SMPS is working and also Processor fan is working.
Monitor is on even smps and processor fan is working but there is response from CPU.
Reason: Automerged Doublepost
06-05-2008, 11:19 PM
Re: No Display
then something is wrong with ur graphic card.....reseat is properly....
My first song
06-05-2008, 11:53 PM
Re: No Display
I've had that problem very often, particularly on rainy days.
I just leave the power on, and the window boot screen appears sometimes after 15 minutes, sometimes after 2 hrs.
And yeah, before all check your ram and remove and reinsert it.
07-05-2008, 06:03 PM
Re: No Display
check if your monitor is working on any other PC, check if any other monitor is working with your pc. the problem will be isolated.
tell us if you have a separate graphics card or you use onboard one.
try to be as detailed as possible.
08-05-2008, 12:39 AM
Re: No Display
Monitor is working and there is no separate graphic card, its onboard.
08-05-2008, 09:14 AM
Re: No Display
As I said, remove ram sticks, clean and reinsert. Leave the system open for few hours. See if it works. For the same problem, it has worked a number of times for me. Try with other ram sticks.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
No Display
fawazz |
QnA (read only) |
13 |
09-02-2007 10:56 PM |
No Display
fawazz |
Hardware Q&A |
2 |
08-02-2007 07:13 PM |
No display
sysfilez |
Hardware Q&A |
15 |
16-09-2006 10:05 AM |
No Display.........
dikudik |
QnA (read only) |
2 |
14-03-2006 07:09 PM |
display
vignesh |
QnA (read only) |
6 |
19-02-2005 06:38 PM |
