Old 05-05-2008, 04:12 PM   #1 (permalink)
Unhappy Damaged DVD:Data Recovery?
I have a scratched dvd that contains a single large rar file.There are some cabinet files in it,and I'am able to extract all of them except one.The shiny surface of the dvd is undamaged.I tried washing it with toothpaste,but no use.Pls help me out...
ashiksn1 is offline
Old 06-05-2008, 03:22 AM   #2 (permalink)
Beta Waves's Avatar
Default Re: Damaged DVD:Data Recovery?
Use Iso buster .... It is pretty good software when compared to other dat recovery software ...
I am Back....
Beta Waves is offline
Old 06-05-2008, 12:33 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try isobuster ......its best 1 ......
... W H O T ...
ax3 is offline
Old 06-05-2008, 01:14 PM   #4 (permalink)
Unhappy Re: Damaged DVD:Data Recovery?
I have Isobuster(registered);but how do I use it?The help file is way too complicated...
ashiksn1 is offline
Old 06-05-2008, 04:30 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Originally Posted by ashiksn1 View Post
I have a scratched dvd The shiny surface of the dvd is undamaged.
how come u have a scratched DVD with undamaged shiny surface
Data Recovery is a part of probability....
Just chec whether printed side is perfect or not the data is stored there only
the plastic is only for support purpose...
Zangetsu is offline
Old 06-05-2008, 08:09 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ There might be a burning error, maybe? Try ISOBuster. Just open the drive in it, navigate to whatever file you want, extract it to your hard disk.
dheeraj_kumar is offline
Old 06-05-2008, 08:55 PM   #7 (permalink)
Tha data layer of the dvd is not damaged.It has no defects at all.The protective transparent plastic coating has a few scratches;that's all...
ashiksn1 is offline
Old 06-05-2008, 11:18 PM   #8 (permalink)
aswin1's Avatar
Easy to use Isobuster. Just open the DVD in the isobuster window and select
the rar file to extract. Specify location. If DVD is damaged it may take ages.
You can also try CDroller another useful software.
aswin1 is offline
Old 29-05-2008, 09:16 AM   #9 (permalink)
Hi, have you tried http://www.diskemergency.com it provides many ways to recover data from disk. You can submit your problem online and get solution in short time. Hope this will help you.
Good luck!
kinsa2612 is offline
tell me about data recovery sonu_mittal1 QnA (read only) 7 17-01-2009 10:21 PM
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
CD data recovery pls help CT Squad Hardware Q&A 1 26-10-2006 01:15 PM
DATA RECOVERY tech skoch QnA (read only) 2 07-07-2005 05:43 PM
please help me.....for data recovery dinesh_singh QnA (read only) 10 30-05-2005 11:24 AM
- by c4u
