Old 03-05-2008, 08:48 PM   #1 (permalink)
Default how to reset the bios password
guys! i need help and suggestions....
my aunt is using PEN3 with (20gb, 128+128 mb RAM, and TOMATO motherboard)
the problem is that..when i went to make her computer...i found there is no CMOS battery in the board and no BIOS JUMPER too..!!!
isnt this something....actually i wanted to reset the password of the BIOS
the BIOS version is AMERICAN MEGA TREND....i want to get to BIOS coz i have alert msg: WARNING CPU speed has been changed!!
but when i press ESC or ENTER for around 2-3 times the password field requied in the BIOS diappears...what now disappoints me....is..the windows xp start loading as soon as the BIOS screen vanish!!
help me..how can i reset the password now???
chandal!
chandal_keta is offline
Old 03-05-2008, 09:23 PM   #2 (permalink)
Seed is the Life!!
shift's Avatar
Default Re: how to reset the bios password
download awflash (or other bios flashing software) and save the bios file to hdd. again update the bios with the file that u saved.
restart.
bios will load the default and password will be gone. u can again set the bios password
Stupidity Causes Cancer !!
shift is offline
Old 06-05-2008, 07:36 PM   #3 (permalink)
thanks buddy and i am really grateful to u...let me try and if not work i wil be back
chandal
Old 06-05-2008, 08:57 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Reset your mobos cmos setting by :
1. Removing the cmos battery fro mobo & about 2 mins later sit it back.
2. Clear Mobos jumper setting ( see manual )
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 06-05-2008, 10:33 PM   #5 (permalink)
Some old bios dont have jumper instead user need to press some key from keyboard before pressing the power button. This instruction is written on mb pcb.
learn how to earn money online : http://howearnmoney.50webs.com
amit_at_stg is offline
Old 09-05-2008, 09:01 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ But Removing the cmos battery from mobo & put it back again some time later really works
topgear is offline
Old 09-05-2008, 09:22 PM   #7 (permalink)
http://feeds.feedburner.com/~r/askVG/~3/284108891/ may help
ThinkFree is offline
How can I reset the BIOS Power On password? ashisharya Software Q&A 9 28-10-2007 10:39 AM
BIOS Reset valtea QnA (read only) 10 27-10-2007 11:05 PM
Reset ur ADMIN password Thilak Tutorials 22 10-03-2007 01:14 PM
Password Reset choudang Software Q&A 8 29-10-2006 10:37 PM
reset BIOS password ????? taken Hardware Q&A 3 15-05-2006 11:19 AM
- by c4u
