CONFIG:
intel core 2 duo E4400 (processor)
Intel i945G/GZ chipset (motherboard)
Intel 82945G express chipset (graphics) [to be upgraded]
200GB HDD
Q1.
I had (512MB *2) ram which I removed after knowing tht vista 32 bit dont support ram more than 4 gb! ... Also i was gettin blue screen saying IRQL_ Not_les_than_ equal ... so might be cuz of this ram ?
Q2.
I got now new (G-skills 2GB * 2) .. CPU-Z says PC2-6400(400MHZ) ? but I bought 800MHZ from the buyer .. y its showing 400 MHZ ?
Q3.
I am upgrading my GPU to "XFX geforce 8800GT alpha dog edition" and smps to coolermaster 600W which I had alredy purchased.. just worried if there would be any heat issues with GPU or cpu or ram etc?
Q4.
Also wanna knw if my pc would run vista 64 bit or not !
Thanks
