Old 02-05-2008, 08:01 PM   #1 (permalink)
Default keyboard problem
i recently got a new pc . it doesn't have ps2 port so he used ps2 to usb converter to connect kb and mouse. now sometimes the keyboard is lit up but it is non functional and same for mouse. i have to detach and reatach for it to work. also suppose if i press two keys they don't work. and f i press one key i.e. hold it it stops after a second or so. this is really irritating since i am unable to play games. everything is in warranty. please help me!!!!
Last edited by upendra_gp; 02-05-2008 at 08:02 PM. Reason: corrected spellings(SOME!)
upendra_gp is offline
Old 03-05-2008, 05:49 AM   #2 (permalink)
Evolving Rapidly...
confused's Avatar
Default Re: keyboard problem
seems to be a problem with the converter/adapter.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
Old 05-05-2008, 11:38 AM   #3 (permalink)
he changed it but still the problem persists. HE says that there's a problem with Graphics Card! he said that the game doesn't support the graphics card and keyboard combo! . somehow i controlled my laughter. but please trell me what to do to tackle the problem. Do u know what he showed to me to tell that the keyboard works. He navigated through the icons on the desktop! I am clueless please help!
Old 05-05-2008, 03:21 PM   #4 (permalink)
Evolving Rapidly...
confused's Avatar
well it could be some hardware incompatibility.(i have no idea what)
few years back, my pc wouldnt boot up when i connected a certain logitech wireless KB. it would progress forward from the bios page only on plugging out the ps/2 KB connector. never solved that problem.
confused is offline
Old 10-05-2008, 07:45 PM   #5 (permalink)
please help people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old 10-05-2008, 07:53 PM   #6 (permalink)
dhanusaud's Avatar
i gaurantee this is incompatibility issue, yeah there may be problem with adapter. I mean signals aren't properly processed as it would work.
you must contact vendor for better results, as the system is under warranty naaa.
ask vendor, wht a hell he had done.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Keyboard Problem shersaha Hardware Q&A 2 14-10-2007 07:23 PM
Problem with keyboard Kalyan Hardware Q&A 1 10-09-2007 06:32 PM
Keyboard Problem Soumyajit Hardware Q&A 1 05-05-2007 08:14 PM
keyboard problem? bhoolkumehul Hardware Q&A 1 27-11-2006 05:43 PM
Keyboard Problem bendre123 QnA (read only) 1 30-06-2005 11:55 AM
- by c4u
