Old 02-05-2008, 06:25 PM   #1 (permalink)
Default AMD 4800+ Temperature
Help to detect problem with my AMD X2 4800+.
It works fine for 30 min to 1 hour after that the temperature raises to 75C and shut down.
Tested Orginal Heat Sink Fan with AMD x2 4000+ is working fine.
But, AMD x2 4800+ is giving problem.
gcbeldar is offline
Old 02-05-2008, 06:41 PM   #2 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Re: AMD 4800+ Temperature
Check whether that heat sink is in contact with the processor properly. If this problem keeps on recurring, carefully remove the heat sink, reapply the thermal paste and put the heat sink back again.
Mine is an Athlon64 X2 4400+ and temp. has never gone above 51 degree C and that too in the afternoon in 40 degree C outside.]
For thermal paste, you can refer to this URL:
http://www.amd.com/us-en/assets/cont...docs/26951.pdf
Shin Estu G 749 is officially approved AMD thermal paste. Unless you can afford to lose void your warranty do not use Artic silver.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Overclocking Amd X2 4800+ & XFX 8800GT Rollercoaster Overclocking 23 22-01-2008 03:45 AM
Athlon 64 X2 4800+ vsCore 2 Duo 1.86 Ghz E6320 hackers2005.3721 Hardware Q&A 12 23-05-2007 04:19 PM
Unable to find X2 4800 vinyas Hardware Q&A 27 27-08-2006 11:34 AM
Cost of X2 4800+ vinyas Hardware Q&A 5 20-08-2006 09:13 PM
AMD X2 4800 And Gigabyte K8NXP SLi Help Berry Hardware Q&A 2 16-12-2005 12:42 AM
- by c4u
