| Forum |
#1 (permalink) |
Oxygen !!
#2 (permalink) |
No pain....No gain
Clean the dust using normal coloring/painting brush and if you can get a air blower (don't use hair dryer) or a can of compressed air, that would help a lot.
Which cabby do you have?
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#4 (permalink) |
I use a vacuum cleaner attached with a soft brush once a month.
Hard to reach areas I use a small hard brush to get the dust fall off.
E6300@3.304Ghz,P5B-Dlx Wifi, 4GB Transcend DDR2 800Mhz, XFX 7600GT,Lenovo 20"Widescreen LCD, Seagate SATA2 HDD 1.5TBx2,Sony DVDRW,Creative 4.1 speakers,APC UPS 800VA,Logitech wireless mouse. |
#5 (permalink) |
Legen-wait for it-dary!
Ask a computer shop for a "laptop vacuum"
I havent tried it, just heard something abt it.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#6 (permalink) |
I tried that it works with usb connected power & its not so powerful to pull the dust.
#7 (permalink) | |
Oxygen !!
isn't cleaning with a brush or cloth going to produce static charge?all the hardware manuals warn specifically about that? |
#8 (permalink) |
Bond, Desi Bond!
check this: http://www.directron.com/cleaning.html
always wear, anti-static wristband while cleaning parts like RAM |
#9 (permalink) | |
instead using high pressure air do cause charge effusion, like vacuum cleaning etc . |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Mac OS X and Linux Left Scrambling for Wow Crumbs in the Windows Vista Dust | Third Eye | Technology News | 27 | 06-11-2007 11:20 PM |
| Microsoft Does It Again: Vista Is the Safest – Linux and Mac OS X Bite the Dust | Third Eye | Technology News | 8 | 20-08-2007 11:15 PM |
| Blowing Dust Out | casanova | Hardware Q&A | 14 | 24-07-2007 03:25 PM |
| DUST IN CABINET | ASH_DSG | Hardware Q&A | 31 | 08-04-2006 07:11 PM |
| Dust and Mobile Phones | iinfi | Mobiles and Tablets | 6 | 29-11-2004 12:45 PM |
