| Forum |
#3 (permalink) |
Fast 'N' Furious
+1 for point No .4
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
#4 (permalink) |
Evolving Rapidly...
@keith - then what timings should one look for? (i am a noob to ram stuff)
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity "Female sexuality isnt a myth" - what i learnt in my first year at college |
#5 (permalink) |
Rising ApocalypsE
Low latency RAMS are better. Look for the lower timings than 5-5-5-18.
U may also find 4-4-4-12 timing RAM.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#6 (permalink) |
Evolving Rapidly...
and how much would "4-4-4-12" 2x2GB dual channel kit (corsair) approximately cost?
#9 (permalink) |
Alter Bridge=GOD
i'd suggest these for around 3000-3400 rupees
http://www.gskill.com/en/f2-6400cl4d-hk.html Check lynx-india.com and gskill rams are of great value.i'd suggest Gskill or corsair.
Apple Macbook Pro 17 |
#10 (permalink) |
Evolving Rapidly...
^^thanks both of you.
#11 (permalink) |
OCZ beats them both at price-performance comparision.corsair=worthless,gskill=good, ocz=gskill costing lesser.i dont mean that both r frm same manufacturers
#13 (permalink) |
Rising ApocalypsE
So True!
OCZ has better value and best performance compared to any other RAM, but OCZ doesn't have any retailer in India. OCZ is like BFG, best value and performance. But no availability. That Platinum series is the best RAM available!
#14 (permalink) |
Evolving Rapidly...
^^so which one to buy, (2 x2GB = 4GB) DDR2 with timings (4-4-4-12) at a budget of 5-7k?
(getting confused, do i go for corsair's 10yr warranty, or do i go for cheaper price?) and if i have to choose b/n "better timings" OR "higher clock speed"? which one to choose? (only thing i have decided is 2x2GB = 4GB DDR2) please help me with the rest.
#15 (permalink) |
Rising ApocalypsE
if u have u choose between 800MHz and 1066MHz then i suggest go for 1066MHz and leave the timing.
If u could make ur mind with OCZ then its good buy, but if u are concerned about after sales service and warranty, then go for Corsair. My suggestion go with Corsair!
#16 (permalink) |
Evolving Rapidly...
thanks keith.
but by the looks of it 4GB DDR2 @1066Mhz is costing 9k(OCZ) or 20k(corsair). so i guess, i cant really afford 1066Mhz. i think i'll go with 800Mhz Corsair. i'll try to squeeze in the best possible timings. thanks again.
#17 (permalink) |
Fast 'N' Furious
I think this would be helpful for all of you :
Download Cpu-z from http://www.cpuid.com/cpuz.php Open the program & hit the SPD Tab to see Ram timings & other infos Generaly Ram Timings are displayed as : ( for example ) 4-4-4-12-15 or 5-5-5-15-18 which translets to : Cas Latency or tcl : It's the number of clock cycles between memory receiving a read command when memory actually starts to read. Ras to Cas or tRCD : It's the amount of time for issuing an active command and the read/write commands. Ras Precharge or tRP : It's the minimum time between active commands and the read/writes of the next bank of the memory module. tRAS or Ras Timing :It's the amount of time between a row being activated by precharge and deactivated. tRC or Row Cycle time :It's the minimum time that a row takes to complete a full cycle.
#18 (permalink) | |
Alter Bridge=GOD
lemme tell u that a pair of Patriot 4gb signature costing 4500 bucks (which i have) is running at 960 mhz...and gskill 4gb pair , the one in my signature , runnng at 1150mhz , costs 14000 and thats the only use of buying these performance rams , besides their timings. 800mhz corsair is enough..
#19 (permalink) |
Evolving Rapidly...
^^ok. but i read an artcle in chip, in which they OCed GSkill F2-6400CL4D-2GBHK, from 800Mhz to 1000Mhz.
consequently the memory bandwith increased from 6216, to 7435MB/s. thats a 20% increase. anyway just had a little doubt. Does OCing neccessarily (read always) void the warranty, or are they exemptions?
#20 (permalink) |
Rising ApocalypsE
Yes overclocking does void warranty!
And i forgot to tell u that price factor. There's is less difference between 667MHz and 800MHz compared to 800MHz and 1066MHz. So 800 MHz is a better option.
#21 (permalink) |
Evolving Rapidly...
ok. yeah i did notice that.
#22 (permalink) |
Alter Bridge=GOD
OC'ing OC rams does not void warranty unless you burn them by extreme overvoltage.these rams are meant for overclocking and not a single stick would sell if they put such restrictions.
Afaik Gskill \ corsair \ ocz gives a replacement on rams gone bad while overclocking .i've got 2 OCZ and gskill sticks replaced thanks to my bro for ruining them and the right voltage for a 24/7 run for Gskill 2*2gbhz (4gb d9gmh) that i run were given by gskill technician only Safe overclocking=No warranty issues ..applicable only to performance ram.. Gskill forum--google it Corsair performance page-read the text-- http://www.corsairmemory.com/testrep...tner_id=325852
Apple Macbook Pro 17 Last edited by nish_higher; 06-05-2008 at 09:50 AM. |
#23 (permalink) |
Alter Bridge=GOD
check these rams--
http://www.lynx-india.com/index.php?productID=1012
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| S 1GB DDR2 @667MHz COMPATIBLE WITH 2GB DDR2 @800MHz | amrawtanshx | QnA (read only) | 1 | 10-03-2008 08:57 PM |
| 4Gb transcend DDR2 800mhz upgrade Ques??? | ranjan2001 | Hardware Q&A | 14 | 20-09-2007 12:24 AM |
