| Forum |
#1 (permalink) |
After I plugged everything back in the computer simply wouldn't start. No response at all. I figured the power supply had picked just that time to crap out so I didn't worry too much. I tested it out with a different power supply with the same result. So then I figured, must be the power button itself or somewhere along the line from the button to the mobo. So I tried a different cases' power button wire and sure enough it worked. So I ordered a new case and it just got here today, but when I plugged everything in I get the same problem again. Is it possible that I have a bad power supply as well as the first problem? Seems a bit coincidental, but... Any help or insight would be appricated. Thanks |
#2 (permalink) |
TechTin.com
Clean RAM chip and fix it in another slot...and properly.
www.9zap.com/forums -> Indian Webmaster Forum whost.in - Web Hosting Offers thinkdigit.com/forum/showthread.php?t=109137 TechTin.com |
#4 (permalink) |
if im not wrong, you didnt remove the motherboard from the cabinets to clean out things..then reseat all connections..cleaning the contact points of ram and pci card with an eraser..making sure not to put your hands all over the circuit boards..and also make sure you touch both of your hands on a metal surface or you can get an antistatic wrist wrap...
if no work then you take out the motherboard from the cabinet and placed it on some thing like your digit magazine or the wrapper of the motherboard if you still have it.and connect all the essential components and power it up... if still no work..then something wrong with hardwares. |
#5 (permalink) |
Cool as a CUCUMBAR ! ! !
dude u have messed up ..... dont use vcleaner, screwsup things when u dont use it properly ......
imo, remove everything ..... take a DRY brush & clean it [dust] slowly .... then attach all ur parts slowly ..... hope it starts .......
... W H O T ... |
#6 (permalink) |
Fast 'N' Furious
Yeah reinsert every components you have - specially rams
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to keep name instead of START in start menu | Batistabomb | Software Q&A | 12 | 08-03-2007 08:32 PM |
| pc don't start | sujeet2555 | Software Q&A | 2 | 16-02-2007 06:31 PM |
| Start menu registry hacks to make ur start menu more bautiful and comfortable | Siddharth Maheshwari | Tutorials | 9 | 22-01-2007 07:01 PM |
| How to start dos always in win 9x | BishnuPurabi | Software Q&A | 2 | 16-10-2005 05:56 PM |
| START UP CD | eureca_eureca | QnA (read only) | 8 | 24-04-2005 04:09 PM |
