Old 30-04-2008, 08:50 AM   #1 (permalink)
heartripple's Avatar
Talking dual os problem
hey guys i was using to os in my pc
1 ) Windows XP SP 2
2 ) Ubuntu 7.10
with my this configuration
AMD ATHLON 64 x 2 4200
ASUS M2N-MX
1 GB DDR 2 667 Mhz
320 GB WESTERN DIGITAL HDD
SONY DRU 170 AW DVD writer
two days ago suddenly my pc got hang for 5 to 10 times. it was not giving me any response.so i decided to reinstall the os.before that problem i installed windows XP first and then installed Ubuntu.
but when i reinstalled only windows xp i knew that now i won't be able to boot into Ubuntu.so guys my question is
( 1 ) is there any way to keep intact my second os when i reinstall
my first os
( 2 ) how can i reload my last setting after reinstalling the os
if this is possible it would be very helpful to dual os users.
heartripple is offline
Old 30-04-2008, 08:57 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: dual os problem
your ubuntu is there intact.only thing is grub is overwritten by winblow$ MBR.
rescue grub(boot menu in linux).go to OSS section for more info.
praka123 is offline
Old 30-04-2008, 09:08 AM   #3 (permalink)
dear it's too late for me that i hev formated the partition of UBUNTU.
Old 30-04-2008, 11:44 AM   #4 (permalink)
Linux Learner
PcEnthu's Avatar
Perform the following steps to keep the linux installation intact even after re-installing the windows:
1. Install windows xp in the primary partition
2. Install your favourite linux in a logical partition and choose not to install any bootloader
3. Download Grub4DOS and extract the file named grldr into the root folder of c drive (Considering c is your primary partition)
4. Create a text file named menu.lst with the bootcodes of your linux install and save it in root folder of c drive
5. Edit the windows xp boot.ini and append the following line
c:grldr="<name of the linux>"
Now, of you format the c drive and re-install xp, you can perform the steps 3,4 and 5 and boot into your linux install
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
PcEnthu is offline
Old 30-04-2008, 11:51 AM   #5 (permalink)
it will work for windows vista
Dual Boot Problem ! coolboy_n Software Q&A 1 15-01-2008 12:54 PM
dual boot problem sthumula Open Source 3 18-10-2006 12:19 AM
Dual OS Problem darshanwadikar Software Q&A 3 10-06-2006 04:20 PM
Dual boot problem? gramesh Software Q&A 1 04-11-2005 12:08 PM
Dual Booting Problem... NikhilVerma Software Q&A 5 30-09-2004 10:37 PM
