Old 29-04-2008, 12:20 PM   #1 (permalink)
midhunmon's Avatar
Default What is Moire? Anyone knows?
What are H-Moire and V-Moire on a computer monitor. Could it reduce a bit of aliasing and if yes what value should i put it. there is a bit of aliasing even if antialiasing is turned on max. i noticed that the same game on a system with same sepcs and diff monitor working fine.
midhunmon is offline
Old 29-04-2008, 05:27 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: What is Moire? Anyone knows?
Moiré is a wavy effect produced by the convergence of lines.
Described as: "wavy lines," "wood grain patterns," "onion skinning," "roping lines," "flashing lines"
http://support.dell.com/support/edoc...8/En/moire.htm
dheeraj_kumar is offline
Old 01-05-2008, 03:06 PM   #3 (permalink)
midhunmon's Avatar
I use those six words(G-O-O-G-L-E) very extensively. I wanted to know if it is related to aliasing in any way. I got lot about moire but nothing about aliasing and moire relation.
Anyway thanx for the response.
Old 01-05-2008, 05:09 PM   #4 (permalink)
its more pronounced when u have striped wallpaper and the color is light, u can see lines running from the edges of the monitor and making archs horizontally and vertically.
Moire setting can be used to remove those lines
Steam/Flickr: psygeist
Asus Z68 V-Pro|i5 2500k|TRUE Black|Ripjaws X+Corsair Vengeance|U2311H|N560GTX|D7000|XONAR STX|RE272|RE0|CC51|XE200PRO Walnut| TD II V2| Ultraphile|N5800
Faun is online now
Old 01-05-2008, 05:15 PM   #5 (permalink)
Google Bot
Pathik's Avatar
Isn't it a wire mesh kinda thing used when rendering graphics?
Pathik is offline
Old 01-05-2008, 05:39 PM   #6 (permalink)
Hey look at these... quite interesting.
http://en.wikipedia.org/wiki/Aliasing
and
http://en.wikipedia.org/wiki/Moiré_pattern
Hey thanks for starting this post, this is definitely an interesting topic.
Old 01-05-2008, 06:38 PM   #7 (permalink)
nope its the defect that CRT monitors suffers
u hav settings to adjust moire Vertical and Horizontal in you monitor setting panel
Faun is online now
