| Forum |
#1 (permalink) |
We decided to go with Motherboard = Gigabyte GA-EP35C-DS3R http://www.gigabyte.com.tw/Products/...ProductID=2740 9800 GTX from XFX 1GB x 2 DDR2 800 MHz We decided to go with quad core Intel Q9300 (2.5 Ghz 1333 Mhz 6MB L2) As we are going with quad core system Does this quad core proccy need any external coller? we would install 500 watts SMPS will it be sufficient?
Gigabyte GA-EP31-DS3L, C2D E8400, 2GBx2 DDR2800 RAM, WD 640 GB HDD (16MB Buffer) CM Extreme Power 500WATS SMPS, Expertvision HD4850 |
#2 (permalink) |
Living to Succeed
I think u should go with 620 watts... as i think that graphic card will need 2 inputs... and an external cooler is always handy to keep the procy cooler and also if u want to overclock it,,...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690 & Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz |
#3 (permalink) |
Down to Earth
I agree with Ajay you should provide extra cooler fans It will prove a wise decision later. Also SMPS should be of higher wattage around 600 watts.
By the way how much you are going to pay for MoBo and Processor ? |
#4 (permalink) |
we will opt for 600 w SMPS
Budget for mobo and procy is around 18000/- he dont wants to overclock his sytem any time does an quad core really require an external cooler?? Really he is not intrested in buying an cooler, instead he says he will pick Core 2 Duo instead of Quad
#5 (permalink) |
Living to Succeed
then go for E8400 which will be a great procy for gaming... but dont compromise on PSU and cabinet..
Quad core is not used to full in the now a days game... it is better u get E8400 or E8500 which is really good processors... i dont think they will need any external cooler if u dont overclock...
#6 (permalink) |
At Hell's Disq
for a gaming system its better to get a E8400 instead of a Quad.
also i wud suggets a 3870X2 instead of 9800GTX.diff in price wud be bout 3k.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#7 (permalink) |
can any one tell why E8400 or E8500 are better than Q6600 quad processor?
and E8400.. are core 2 duo processors or what kinds of ? and then for what kinds of things Q6600 is good? like high end software running? application servers etc.? and other tech. stuffs ? |
#8 (permalink) |
At Hell's Disq
^^^ E8400 & E8500 perform better in current apps and games cuz of their higher clk speed.most of the apps that we use 2 day r not optimised for quads so they dont perform well on Quads.
quads perform better in image and video editing. E8400 is a C2D procy but its fabrication is 45nm whereas prev C2Ds were 65nm fabrication.
#9 (permalink) |
Living to Succeed
Quad core is really beneficial for multimedia works as well... like in 3D applications all 4 cores are used... which games dont use... might be in future they will use that
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| HELP: Building a new website. Some queries related to it. | The Unknown | QnA (read only) | 12 | 19-10-2007 06:36 PM |
| Help : Building A PC. | MIT | Hardware Q&A | 5 | 09-05-2007 09:00 PM |
| Building a new PC | indyeah | QnA (read only) | 3 | 30-10-2006 09:23 PM |
| Need help in Building a PC | troubleshooter | Hardware Q&A | 11 | 17-04-2006 09:40 PM |
| Building a new rig | jayavardanavel | QnA (read only) | 6 | 22-05-2005 04:47 PM |
