Old 28-04-2008, 12:44 PM   #1 (permalink)
midhunmon's Avatar
Unhappy Monitor display goes blank
Recently while i am working on my pc the monitor suddenly goes blank. it has happened twice. Oce it came back immediately and the other time i had to go to standby mode and then back to get the display. i think the green power led on the monitor is still ON. So the signal might be there. Is my monitor dying?
midhunmon is offline
Old 28-04-2008, 02:49 PM   #2 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Default Re: Monitor display goes blank
Maybe problem with the display adapter or the cable. Monitor is not getting proper connection.
john_the_ultimate is offline
Old 01-05-2008, 03:10 PM   #3 (permalink)
midhunmon's Avatar
Yes the monitor is getting the signal alright. I noticed that whenever it happens the green power LED is ON (not blinking) and if you switch OFF the monitor and then power ON it again then the display comes back.Might be something loose in the monitor. its been repaired of late as it was damaged due to a power surge.
Display going blank after the xp loading screen soumya Hardware Q&A 5 26-02-2007 04:24 PM
blank monitor screen with upgraded PC paul_007 Hardware Q&A 10 12-01-2007 12:46 AM
my monitor is blank!! help anzaan Software Q&A 5 01-12-2006 03:32 PM
Monitor went blank (Urgent) rahul_2350 Networking 5 02-08-2005 09:07 AM
how to attach 6 devices ? display going blank vaishali Networking 15 19-04-2005 02:40 PM
