Old 28-04-2008, 12:49 AM   #1 (permalink)
Noobie Pro
alsiladka's Avatar
Default Suggest a Budget Motherboard for AMD M2 Socket
Guys please suggest some budget MBs for AMD M2 socket. Budget is between 2 to 3 K.
Would prefer onboard graphics better than Nvidia 7050/630i.
Also, any board with 2 Lan ports?
And which would be the cheapest HDMI output MB?
I have to assemble 2 3 pcs for our offices and one as a cheap HTPC.
One of the PCs i plan to use as a centralised computer, less than a server.
www.twitter.com/alsiladka
alsiladka is offline
Old 28-04-2008, 09:19 AM   #2 (permalink)
Default Re: Suggest a Budget Motherboard for AMD M2 Socket
U can go for M2A-VM from asus which is 690G based and better than nvidia 7050 imo (have got both). but will reach ur upper limit. or u can have jetway mobo based on 690G which will definitely cost less than 3k. havent come across a mobo withe 2 lan ports. u can always buy an extra add-on card for around 300 bucks. However if u want the mobo for HTPC, the best option at the moment will b AMD 780G based mobo from gigabyte which has hdmi but will cost around 4700.
varunprabhakar is offline
Old 01-05-2008, 11:19 AM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
Is AMD 780G better than nVidia 7050? What is the onboard GFX on 780G?
Old 01-05-2008, 12:23 PM   #4 (permalink)
yes definitely much better. infact this is the best onboard grafix available atm for htpc. it has "Integrated ATI Radeon HD3200 graphics (DirectX10)" and with "ATI Hybrid CrossFireX support".
Old 02-05-2008, 12:10 AM   #5 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Only High-End motherboards support Dual Lan options!
keith_j_snyder2 is offline
Old 02-05-2008, 07:37 PM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ Right said pal
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 03-05-2008, 06:06 PM   #7 (permalink)
Noobie Pro
alsiladka's Avatar
Originally Posted by topgear View Post
^^ Right said pal
Couldn't you find any other way to increase your post count?
Old 04-05-2008, 08:16 PM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
I am not in no way increasing my post count - I just tried to help you out
as more positive opinion for a post the more one will confident to follow that post.
Also if you you surveyed the market & browsed the web sites you will come to know it's a silly idea to expect a dual lan board under Rs. 3000 budget..
Do market survey & browse a few e-shoping website & you will come to know what I am trying to tell
Go to this website to get a idea abt prices :
http://www.theitwares.com/motherboards/motherboards.htm
topgear is offline
suggest a good 775 socket Motherboard.. shyamno Hardware Q&A 3 05-01-2007 07:29 AM
