Old 27-04-2008, 11:32 AM   #1 (permalink)
Angry flash drive problem
Sir,
I have 8 gb IBM flash drive, purchased a year before.
I am facing problem with it. It cant be opened and formatted and it is showing raw file system, 0bytes allocated and o bytes free.
I tried with lts of softs but it didnt worked
Please guide me!!
Prashant Satpute is offline
Old 27-04-2008, 01:50 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: flash drive problem
It maybe a fake. Try low level formatting it.
www.hddguru.com
http://h20000.www2.hp.com/bizsupport...X-UNITY-I23839
dheeraj_kumar is offline
Problem with pendrive/flash drive bhanu210 Hardware Q&A 8 06-03-2008 01:58 AM
dll problem in removing flash drive psnegi26136 Software Q&A 1 22-01-2008 07:54 PM
JET FLASH Usb drive problem mrbgupta Hardware Q&A 2 30-11-2007 10:55 AM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Flash Drive problem? vinith98 Hardware Q&A 3 31-01-2007 06:20 PM
- by c4u
