Old 26-04-2008, 09:36 AM   #1 (permalink)
Default Which Motherboard to choose? (ATX)
Hi
I am building a budget pc for the following use
* It will be mainly used as an Office PC in a Home/ Office/ Shop setup
* There could be occasional gaming (no 3D) or movie/ video watching
* No overclocking
* Should be durable in a non-AC environment
I am thinking of going with either the E2160 or E4500 C2D
I am considering P35 or G33 or G31. i am not sure which one is good for the budget and the purpose.
These are the motherboards I have in mind. Please suggest any good option other than the following also:
- Abit IP35-E
- Intel DG33FB
- Intel DP35DP
- Asus P5KPL-C
- Asus P5KPL-E
Can you please help me with a good suggestion?
Thanks.....
tmbsundar is offline
Old 30-04-2008, 07:28 AM   #2 (permalink)
Default Re: Which Motherboard to choose? (ATX)
I guess P35 doesn't have on-board gfx. If you don't want to use additional gfx card, g33 would be best. Otherwise go for p35 with some cheap gfx card (8400gs).
hsetir is offline
Which one 2 choose??? latino_ansari Open Source 3 26-02-2008 01:05 PM
Help Me To Choose sourav237 Mobiles and Tablets 6 12-08-2007 08:38 PM
N80 vs. N73..Help me choose! Ankur Gupta Mobiles and Tablets 48 26-05-2007 08:30 PM
Help me to choose parimal Mobiles and Tablets 14 18-05-2007 04:08 PM
Help me choose Kalyan Mobiles and Tablets 10 24-01-2007 12:10 AM
- by c4u
