No display on the monitor? What's the problem please help!!!!!!!!!!!
My friend's system config:
Q6600
Biostar 35 M/B
CM 500
Trans 2x1 gb
WD 320 gb
Viewsonic VX2255wmh
Xfx 8600GT
After Switch on the system, the CPU fan and Harddisk are start to work but we wouldn't get the display on the monitor and as well as the LED's in the motherboard are not lighting?
Re: No display on the monitor? What's the problem please help!!!!!!!!!!!
whats the max resolution suported by the monitor...?
have you switched monitors recently?
if you have specified a higher resolution in yr pc.....then the computer will boot up no doubt.....
but the monitor wouldnt work right during the logon screen...
if this is happening take yr Cabinet to a frnds house who has a fairly high res monitor...and decrease yr resolution using his mon....
in view sonic monitors if the res is not proper it auto adjusts itself...it sais "auto adjusting imgae" and lowers the resolution...try reseating ur gfx card,removing CMOS battery and putting it bak again,changing RAM slots...
My site: collegeclassroom.org
