Where are you getting the TRUE-120 from?? I would advice that you get the fans from the same source (Panaflo or Scythe). In kolkata you can get Coolermaster/Antec 120mm fans. Or else local branded 120mm are available for around 80-100 bucks from any shop.
I use a Logisys 120 mm blue LED fan with the Ultima90i ... it does ~76 CFM at ~1700 rpm , and is quite enough to mix with the sound of the remaining contents of the cabby .. the only problem is that this one is not available here .. i shipped mine from mumbai ...
BTW .. u getting the Ultra120E in kolkata ?? What's the premium ??
Lots of option for fan and coolers plus reliable. Talk with Mr.Gulbir, he and his team will help you out.
