Old 24-04-2008, 06:17 PM   #1 (permalink)
Default hardware problems
While installing Windows XP software computer shut down automatcally
where is the problem in my pc , please tell
sagar wale
sagarwale@gmail.com
Mobile 9109890174723
sagar3386 is offline
Old 24-04-2008, 08:08 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: hardware problems
1st of all don't post your contact information like that.
for the problem post your detailed hardware details with smps
config.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 24-04-2008, 11:23 PM   #3 (permalink)
The Revolutionary
thetillian's Avatar
Hey this problem exists in the following cases try these
1. When the OS is corrupted.
2. When the RAM is damaged.
3. When the Hard Disk gone bad.
4. Or else When the RESET button is struck.
Try these
thetillian is offline
Old 25-04-2008, 12:16 AM   #4 (permalink)
dOm1naTOr's Avatar
This one happened due to drive problem also. To check if ur system is faulty, boot with some live CDs.
More info bout the situation cud bring u better help.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 25-04-2008, 12:26 AM   #5 (permalink)
It's true Im not confused
confused!!'s Avatar
NMI
After the game is over, the pawn and the king go into the same box
confused!! is offline
Post ur mobile internet queries, problems n problems here sourishzzz1234 Buying Advice 2 19-01-2008 07:34 PM
Problems with hardware-help jandrews Hardware Q&A 3 14-08-2007 12:03 PM
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
hardware problems??? sumsatdigit Hardware Q&A 1 15-02-2006 11:33 AM
Software for Hardware problems kumarn_2004 Software Q&A 3 19-06-2005 11:17 PM
- by c4u
