Old 24-04-2008, 09:51 AM   #1 (permalink)
Unhappy My HDD crashed!!
I have a problem with my PC. I wanted to repartition one of my drives(it was empty then) and so used PAragon Partition manager for the same. But during the process, a power shutdown occurred. After that the partition I worked on and 2 other partitions next to it got corrupted. The other partition contains 30 GB of My Documents. I recovered the partition with Acronis Disk Director ( PMagic does not even start, says there is a problem in the Partition table info ) and the data using Stellar Phoenix Windows Data Recovery. But still some directories show up empty and not all files are recovered. The other two partitions do not even show up. They are discovered as RAW partitions. I know this is a long shot, but any suggestions as to what can be done ?
AMD Athlon 64 3000+ [ Venice core ] , Asus A8N - E Motherboard, 1 GB DDR 400 Transcend RAM, Leadtek 6600 GT Graphics card, Hitachi 160GB 7200rpm SATA 2 running Windows XP Professional Edition with SP2
Aparajith is offline
Old 29-05-2008, 09:19 AM   #2 (permalink)
Default Re: My HDD crashed!!
Try http://www.diskemergency.com where you recover your data easily. You just submit your problem online and get the job done in short time.
kinsa2612 is offline
Old 29-05-2008, 09:34 AM   #3 (permalink)
u can also use this..................
http://hddguru.com/content/en/software/
download PARTATION FIND AND MOUNT software....this allows u to recover deleted partitions. What's special in this program is that it allows you to mount lost partitions right into the system, so the operating system sees that lost partition like a good one.
This software also has the possibility to create and mount images of the entire hard drive or separate partitions. good luck
chandal
chandal_keta is offline
Ktorrent crashed often gary4gar Open Source 4 03-10-2007 06:59 PM
Linux Car Crashed & came last gxsaurav Technology News 4 30-05-2007 03:58 AM
bios crashed readermaniax QnA (read only) 11 11-08-2005 03:40 PM
GAMES WHICH WERE HOT BUT CRASHED?? wizrulz Gamerz 26 07-08-2005 06:14 PM
- by c4u
