Old 23-04-2008, 09:01 PM   #1 (permalink)
Default sony dru 830a not reading dvd-r
i bought sony dru 830a year back based on digit recommendation.now from a month its not reading dvd-r format.most of the time it does not read dvd-r.
one time i burned dvd-r with slowest speed possible and tried it in my friends comp,it is reading in his comp.when i tried the same in my comp it reads it as blank cd.all digit dvds read fine.i even flashed the firmware to new version ss25 from ss23.what could be the problem??
sreenidhi88 is offline
Old 24-04-2008, 03:39 PM   #2 (permalink)
Default Re: sony dru 830a not reading dvd-r
it is going to fail soon...once that happen gradually, u wont even be able to read digit dvd..
realdan is offline
Old 24-04-2008, 11:26 PM   #3 (permalink)
The Revolutionary
thetillian's Avatar
Try using lens cleaner or service your DVDWriter if you know (Do it at your own risk)
thetillian is offline
Old 25-04-2008, 07:22 AM   #4 (permalink)
Just a techno junkie
roxysmile's Avatar
its due to weakness in the blue laser which is used to read the dics
u may change the laser but i think now optical drive are very low in cost so try to get
lite on or asus drive with 20x read capability (costs u just 1.2k to 1.5 k)
roxysmile is offline
Old 12-07-2008, 11:56 PM   #5 (permalink)
luckysmeg's Avatar
I m also facing same problem,with The DVD-RW,,it can write DVD-r,but cant read them.
and i would also like to mention that the same DVD writer is able to read the same DVd's in Win98,which it is not able to read in WinXp,
Can you please suggest a solution to this?
Waiting eagerly for your reply.....
luckysmeg is offline
Old 14-07-2008, 04:53 AM   #6 (permalink)
change the ide cables from 40 conductor to 80 conductor.
if its still not reading ,go to device manager uninstall ide ata/atapi controllers and restart.
now it shud sttart reading.no lens or any other problem.mine's working perfectly now.
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
Problem reading DVDs written by SONY AW-G170A joy.das.jd Hardware Q&A 5 26-04-2008 11:14 PM
Sony DRU 830A ak24 Hardware Q&A 5 25-01-2007 07:33 PM
DRU-830A or DRX-710UL hell_storm2004 Hardware Q&A 3 01-01-2007 11:29 AM
CD-Rw is not reading brshravan Hardware Q&A 3 09-08-2006 10:33 AM
Problem Reading Files In SONY CDRW dragonball QnA (read only) 6 22-10-2004 05:07 PM
- by c4u
