View Poll Results: Which optical drives(dvd writer) to buy?
Samsung SH-S203D 3 37.50%
LiteOn LH20A1P 2 25.00%
Sony DRU 190A 0 0%
Sony DRU-845s 0 0%
ASUS DRW-2014L1T 3 37.50%
Voters: 8. You may not vote on this poll
Old 23-04-2008, 02:37 PM   #1 (permalink)
Default Buying Optical drives
I am looking to buy an optical drives capable of burning CD and DVD media and that basically means the need is a DVD writer.
I am confused and can't decide which one to buy especially because one cannot rely on reviews anymore.
The better test to decided what to buy is reliability and users experience counts a lot so if you don't have any issues with the drives u have bought and think it appropriate to suggest it. Pls do so.
I don't want a fast drives which end its life fast too.
Pls suggest what model of dvd writer to go for which is currently available in the market.
realdan is offline
Old 23-04-2008, 05:51 PM   #2 (permalink)
pratik03's Avatar
Default Re: Buying Optical drives
Samsung SH-S203D (SATA Interface)
Silent & fast. brought it 1 week before.
faster drive doesn't mean shorter life
pratik03 is offline
Old 24-04-2008, 11:31 PM   #3 (permalink)
The Revolutionary
thetillian's Avatar
Go for Samsung or others the LiteOn is the best.
thetillian is offline
Old 24-04-2008, 11:58 PM   #4 (permalink)
Its Best only if its open
ankushkool's Avatar
liteon or samsung... no doubt
ankushkool is offline
Old 25-04-2008, 12:01 AM   #5 (permalink)
Optimus Prime
Thumbs up Re: Buying Optical drives
Ya realdan...go for da Samsung SH-S203D
it costs around INR 1,200/- and is a steal at such a price fr the performance...
just make sure ur Motherboard has an empty SATA port...as this Writter sports the new SATA Interface...
capt.rej is offline
Old 25-04-2008, 01:07 AM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
nope samsung is not known for it quality. I am surprised no body recomended sony, or ASUS. I have used all DVD drives for years and I can say Sony never gave any problem in any department, then liteon (relatively) new, and recently I tried ASUS SATA DVD RW, is working like a charm for the past 6,7 months.
sam9s is offline
Old 25-04-2008, 08:23 AM   #7 (permalink)
TheSaint
NucleusKore's Avatar
LiteOn LH20A1P
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 25-04-2008, 09:18 AM   #8 (permalink)
Ethan_Hunt's Avatar
Lite-On LH20A1P is a noisy drive.Needs firmware update to read Dual Layer DVD's.Had it for close to a year.Didn't have major problem burning DVD's till now.Ocassional switch to PIO mode(once) & minor tray issue(2 times).That's about all that I have come across & nothing apart from that.It had failed 4 DVD's in a row once but I suppose I had a bad luck with those media.After that it had worked fine.
V for Vendetta
Ethan_Hunt is offline
Old 25-04-2008, 09:44 AM   #9 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Sony DRU 190A
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 25-04-2008, 10:46 AM   #10 (permalink)
damn busy...
utsav's Avatar
ASUS rocks without a glitch . i am very satisfied. I have lost three samsung octoedge drives so samsung is a big NO
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 25-04-2008, 11:16 AM   #11 (permalink)
channabasanna's Avatar
I have a SAMSUNG DVD Writer, which i have kept it away now as it is a junk. SAMSUNG has lot of problems in its tray. I have never used the Drive roughly like pushing the tray inside or inserting a pin to open the tray.
Whenever i press eject button it used to come after 3 or 4 presses of the button, so when in warranty i got it serviced from SAMSUNG. Again few months ago i had same issue.
So i decided to change the drive, hence brought a SONY DVD Writer, now when i just opened the tray of SAMSUNG i found that the Gears in the tray were broken for almost 1 inch of length.
I would say build quality of SAMSUNG optical drives is very bad. I even have seen the same issues in 2 of my friends system's.
I would say SONY.
C2Q Q6600 G0|ASUS Maximus Formula|XMS2 1GB x2|CM extreme Power 600W|CM Elite 332|WD 320GB HDD|Seagate 80GB HDD|SONY DVD+RW|Viewsonic VA1912wb 19"|XFX 7600GS|OCZ Vendetta 2|HP dv2601tx|Nokia N73 ME
channabasanna is offline
Old 25-04-2008, 02:36 PM   #12 (permalink)
TheSaint
Yes like an aeroplane taking off
Like DIgit DVDs? Yes, and its through a nice GUI flasher provided by LiteOn the firmware can be updated, no shell or dos commands to fiddle around with.
Have it now for a year and a half, no problems.
Old 25-04-2008, 06:29 PM   #13 (permalink)
the thing is i have never ever bought a samsung...that was when people said about quality issues with their drives
so far i have only used sony, liteon..i should say i have issue with both..failed to read/write dvd in both the brands.
i still have sony dru-810a using it in another PC for more than a year at least..dont remember exactly when i bought it...
the Sony AW-G170A..that i bought wasnt reliable and failed to read/write dvd now..even when it was working it took longer to read dvd..which means slower than the dru-810a..at least in my case..or maybe i m just unlucky to have the problem
i bet the samsung drives model recommended is still very new and people may not have used it to the extent to judge its quality..isnt? oh! that particular model was recommended by digit as editors pick..
what about sony dru-845s? have anyone burnt heavily with it? is it performance and reliability good?
realdan is offline
Old 25-04-2008, 07:25 PM   #14 (permalink)
pratik03's Avatar
samsung had quality issues & tray porblems in their older models
but in this new model (SH-S203D) tray quality, read/write speeds & overall build quality are much better than previous model
also it is much faster than my older sony drive
all other members blaming samsung try this model
pratik03 is offline
Old 25-04-2008, 09:34 PM   #15 (permalink)
looks like this time samsung managed to get it right...from what i see
pratik03 subject the tray in and out mechanism to an intensive test ..maybe not on the one u have but somebody else
realdan is offline
Old 25-04-2008, 09:48 PM   #16 (permalink)
bajaj151's Avatar
I have updated my firmware to the latest (KLOP)....but still digit dual layer dvds not reading on my drive.
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Old 25-04-2008, 10:32 PM   #17 (permalink)
u shud go in for Sony DRU 190A ... if money isn't an issue , go for ASUS
Old 26-04-2008, 06:53 AM   #18 (permalink)
TheSaint
Download patch
Disconnect from the internet
Disable all antivirus, firewall, active defense, etc.
Run the patch
Reboot immediately after it's installed
Firmware: http://www.mediafire.com/?yzflzi0icg0
Old 26-04-2008, 11:12 AM   #19 (permalink)
bajaj151's Avatar
Originally Posted by NucleusKore View Post
Download patch
Run the patch
But I already updated my firmware...
bajaj151 is offline
Old 26-04-2008, 11:44 AM   #20 (permalink)
TheSaint
Then try again, it will overwrite it but do it as outlined above
Old 27-04-2008, 01:12 AM   #21 (permalink)
i m scared of the sony dru-1xx range...did you buy it?
which asus model..is it drw-1814BLTor drw-2014L1T? anyone have real life experience using them?
realdan is offline
Old 27-04-2008, 11:39 AM   #22 (permalink)
Cool Buddy's Avatar
if u r buying lite on make sure the service centre is closeby and plz buy a 2nd drive of another company bcoz once ur liteon stops working and u give it to the service centre it will come back only after u have exhausted ur warranty, till then it will stay in Singapore or Germany or wherever there company is locted. The fact is its the worst drive and the service is PATHETIC. I hate digit for recommending these to everyone.Speaking from personal experience. I made the mistake of suggesting liteon to my friends and they r no longer my friends.
Cool Buddy is offline
Old 27-04-2008, 05:43 PM   #23 (permalink)
yeah ... i got it and found it better than Samsung !
for asus ... drw-2014L1T
Old 28-04-2008, 09:41 AM   #24 (permalink)
Point Blanc
how can I get sony DRU-8xx series writer, here in locals, I see only DRU-190A, but 810A seems to be much better than 190A.
acewin is offline
Old 02-05-2008, 01:12 AM   #25 (permalink)
it seems different people have recommended different model..lets have a poll to decide
realdan is offline
Old 02-05-2008, 10:17 AM   #26 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Did you consider the option of buying a USB DVD Writer ?
techtronic is offline
Old 02-05-2008, 10:22 AM   #27 (permalink)
left this forum longback
praka123's Avatar
samsung and problems-it is not relevant now.it is just FUD.dont compare old samsung drives.now samsung has changed quiet a bit
praka123 is offline
Old 02-05-2008, 10:27 AM   #28 (permalink)
csczero's Avatar
Dude ....try LG .....its reliable
DELL 1500 Vostro , Playstation 3, LG LD460 42" , Nokia E5
csczero is offline
Old 02-05-2008, 11:48 AM   #29 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Dont get any Optiarc drives from Sony. They suck. They cant read DVD-Rs after some time. You need to reflash firmware, which might work in some cases, but most ppl prefer an exchange.
dheeraj_kumar is offline
Old 03-05-2008, 05:37 AM   #30 (permalink)
Evolving Rapidly...
confused's Avatar
AFAIK sony is just a re badged benq.
and been using benq for 2 yrs now. no probs yet.
http://qbitmesra.blogspot.com - Quenching BIT's Quriosity
"Female sexuality isnt a myth" - what i learnt in my first year at college
confused is offline
How to 2-3 optical drives Sridhar_Rao Hardware Q&A 9 21-11-2007 10:49 AM
Where are my Optical Drives? emailaatif786 Hardware Q&A 5 24-01-2007 02:06 PM
SATA Optical Drives ?? varun_ag QnA (read only) 12 28-04-2005 11:41 PM
Installing two Optical Drives sid_b6505 QnA (read only) 4 24-03-2005 09:11 AM
Full form of some abb. used in optical drives chirayu garg QnA (read only) 3 20-11-2004 08:44 PM
- by c4u
